Horsepower
- Bobby74
Horsepower
Without looking at the motor, 140HP. I was close wasn't I? I know a 2007 with simular config is 147HP.
Horsepower
This is the first stroker I've built.I was thinking it should be around 140hp by basing it off some other engines i have seen, I'm gonna upgrade the Heads a little later on to some street eliminators from Moore Parts that have 44X37.5 valves and do some work on the carbs and raise the compression up to around 9:1.Maybe then i will jump up to around 170+hp.What do you guys think or suggest,would that bring me up to 170hp or so, how about putting some ratio rockers on im not sure if my cam(engle 120) is compatible with them or not and would that maybe help some.
Thanks,
Mike
Thanks,
Mike
Horsepower
I'm putting the finishing touches on my motor its a type1 2275cc 120 cam and 042 heads with 8.5 compression Dual 44 webers.What would this thing be putting out for horsepower.I have a figure but I wanna see what you guys think.Thanks,
Mike
Mike
Horsepower
Needc more info on heads and exhaust but with stock heads? say 85 hp .....decent porting would kick it upto say 120 or so
Horsepower
The heads have been ported and have 40X35.5 valves and 1 5/8 merged dual QP exhaust
