Supercharger and cooling
funkSoulP
Post by funkSoulP »
Jake, I read that you had built some supercharged engines, and are planning to build more in the near future. How did you solve the cooling on those engines. I saw one that had a flat fan on top, like a Porsche 917.
Have been fooling around some time trying to think of a way to build a "daily" driver with a supercharger. My problem is how to fit it all under the hood. The blower (Eaton M45) is too long to fit beside the alternator with an upright cooling in a beetle.
With a Porsche fan there is room for the blower, how about the DTM? It is slightly offset compared to a T-1 shroud so a few cm more space, I assume?
And how about the driveshaft of the blower? It is longer than necessary and I can't find any reason why it must be that long. Is it possible to make a new nose piece with shorter shaft?
cnavarro
Post by cnavarro »
I can't answer the fan question exactly other than to say that the flat style fan is a poor solution, even worse than the 911 style shroud. If the DTM can be made to fit, Jake can do it. Cylinder wise, you'd probably want to stick to a smaller 90.5mm bore or at the largest, a 93 or 94mm bore depending on how much boost you'll be building. I would assume 5 psi on a 93 or 94 bore would be fine, especially if you step cut the heads. Any larger than that, you'll want a set of Nickies. Jake's currently working or a large displacement turbo engine that he'll be using a set of thickwalled Nickies for- we have three to choose from, including a 98, 100, and 102mm bore, all based on the registers of a STD 103 cylinder, so they are interchangeable in that respect. On the thicker 98s and 100s, you can get away even with flame ringing using 911 components for a physical interlocking seal.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
dstar
Post by dstar »
cnavarro wrote:....... On the thicker 98s and 100s, you can get away even with flame ringing
Charles Navarro
LN Engineering
HEY Charles, thanks for the parts!
:D
Anywho, what is this flame ringing you are talking about?
I had thought about machining a groove in the head for a viton seal.
Is that it?
Fast German Auto has the o-rings for sale.
Don
MASSIVE TYPE IV
Post by MASSIVE TYPE IV »
I wouldn't buyy a damn pushrod tube seal from them!
The process isn't that simple anyway to be done correctly for the best resullts.. We are going to run 20+ PSI boost on this 2.7L engine, and with a few Turbo enhancements it whould make some sick power AND retain its reliability..AND its longevity!
the_troupster
Post by the_troupster »
Wow! That's got to be pushing 600+bhp...?
With regards to supercharging, you've got no choice but to go Porsche style cooling in my opinion. Do a search for Moggy on here for a 'here's one a made earlier'. He's running a M65, which is a good cheap unit. But if your just testing the water, Google for Kenne Bell. This dude makes frickin' awsome blowers.
Jim
PS. How about using a wasserboxer case, Jakes billet heads, Nickies.... oooh, the list goes on! :wink:
cnavarro
Post by cnavarro »
Don,
Here are a few threads from Pelican Parts on the topic of flame ringing. It's to make a long story short, a physical interlocking ring that is mated with a groove between the head and cylinders capable of withstanding extreme temperatures.
http://forums.pelicanparts.com/showthre ... flame+ring
P.S. Hope the spacers work out well! If not, I can send you more and you can use them as building blocks!
Charles Navarro
LN Engineering
MASSIVE TYPE IV
Why would one think that Porsche style cooling would be a must?? I ask this simply due to the facts I have proven in the past few years that clearly show the Porsche style fan is the worst arrangement off the shelf to keep head/cylinder temps lowest and the most even.
I have 4 Turbo TIV projects planned for 2006 and one super charged engine. All will utilize the DTM for cooling.
The first one is well underway for my 914...
dstar
Post by dstar »
MASSIVE TYPE IV wrote:I wouldn't buyy a damn pushrod tube seal from them!
WOW! They did you that bad in the past, eh?
:shock:
Don
dstar
Post by dstar »
cnavarro wrote:Don,..... Hope the spacers work out well!
Charles Navarro
LN Engineering
BUWAHAHAHAHAHHAHAHAHAHAHA!
Yea, I have got my BLING on now, I have 10 RINGS on my fingers!
8) And six on my TOES!
:wink:
I'm sure they will be fine. I WILL need another couple sets if I can find
more stroker crankshafts though, so don't sell em ALL!
:lol:
Don
the_troupster
MASSIVE TYPE IV wrote:Why would one think that Porsche style cooling would be a must?? I ask this simply due to the facts I have proven in the past few years that clearly show the Porsche style fan is the worst arrangement off the shelf to keep head/cylinder temps lowest and the most even.
I understand the benifts of your DTM shroud (fantastic work by the way). I was refering to the space constraits within a Beetle's engine bay for a supercharger. I'll be very interested in how you 'charge a TIV with a DTM.
I didnt mean to confuse.
Jim
MASSIVE TYPE IV
I have done it 3 times... You'll see later on if you pay attention here around the end of 2006/
funkSoulP
Post by funkSoulP »
Jake, what supercharger will you use with the DTM?
The Eaton is quite long, but there are other good (or even better) alternaives. The Eaton just happens to be available at low price.
Wally
Post by Wally »
cnavarro wrote:I can't answer the fan question exactly other than to say that the flat style fan is a poor solution, even worse than the 911 style shroud.
Charles Navarro
LN Engineering
Hi Charles,
Please explain the above: Why would that be so?
AFAIK, even Jake hasn't tested any flat style fan assembly's ... (actually there is/was only one commercially available: Riechert, Germany) and apart from robbing more power obviously, the cooling of a flat set-up should theoretically be very even - just because the way it is positioned over the engine :?
Thanks,
Walter
T4T: 2,4ltr Type 4 Turbo engine, 10.58 1/4 mi
www.apfelbeck.nl
MASSIVE TYPE IV
Yep, I have never directly6 compared the horizontal set up against anytyhing else..
I can see some issues with tangential flow due to the air not having much room to be diverted to the left bank cylinders, but thats pure speculation at this point.
funkSoulP
Post by funkSoulP »
The flat style cooling in the 917 was not bad at all. According to some sources, it moved 2400litres of air per second.
I guess that the flat fan arrangement could be made to work very well. The problem is how to drive the fan. I've seen some autocross cars with a belt drive, and they usually throw the belt frequently. The 917 had, I think, a shaft driven fan. Someone also said something about a torque converter in the fan, but could have been some other engine (908?).
Locked
