compression ratio
sixt4vdub
compression ratio
Post by sixt4vdub »
10.1 CR is this safe to fun on a 2056 and how will i benefit from it??/
MASSIVE TYPE IV
Post by MASSIVE TYPE IV »
what cam?? what heads?
Choosing CR above 9:1 without basing your decision on these two things and the operating conditions is not very wise..
In short Cam dictates CR that is considered safe for pump gas..
sixt4vdub
Post by sixt4vdub »
heads 914 2.0 heads ported polished 44x38 cam i am hoping to get your recommendation on that. I will have flow numbers soon
MASSIVE TYPE IV
Flow numbers are a must...
whats the intended application, where do you want the power?
What other parts are you coupling this to?
sixt4vdub
Post by sixt4vdub »
2056 44Webers updated heads as mentioned aboveintent is to hopefully increase horsepower , cam ,mallory dizzy will be purchasing from your store. im guessing this motor will spin to 6500 so i would like a broad powerband.
Locked
