I intend to buy the majority of bits from jake but dont want an egine kit
cam rods pistons cylinders rods etc
machine services are kinda limited, and where technicaly machined bits are needed beond the wideing of cylinder bores or similar well, that will dictate another purchase from jake
I have at the minute two unknow 914 engines and a bus 2 litre and plan on using 914 gear ratios
the engine is going into my '68 912
I like the prospect of twicw the factory HP and bags of torque
for donuts and power slides-IN THE DRY!!
will need to commute about 1 hour at a time in traffic( drove ten miles the other day in first gear
jake you hinted at a train of thought on the type 4rum and so I'm dyin to know what you would have in mind.
cheers
colin
