the most important issue is the rust free...
budget 1500-2500$
7325867799
thanks a lot
looking for a 73-75 914 2.0
Rust free as in never been rusty, or has been repaired?
I'm just asking because you either need a bigger budget, or you need to be more specific about what areas you are willing to do work on.
If you want a 73+ car that has never been rusty, and runs great, with a straight body, good interior, etc., you'll need a bigger budget.
So do you like to do engine work, body work, or what?
Depending greatly on location, a straight runner 73+ 2.0 with minimal rust could set you back $5K easily.
A pretty straight car with a blown/missing motor/tranny would likely be in budget, and a "running" 2.0 motor can be had for $250 complete if you have good junkyard shopping skillz...
I'd strongly suggest considering a motor and straight car as separate projects.
Keep the car/motor hunt separate and that's quite reasonable.
OTOH, you might get lucky.
(again, depends greatly on where you are, and you don't have that in your profile)
Keep in mind that even if the motor runs great, it is a VERY good idea to have the heads "done" ASAP by a reputable T4 aware head shop... very short list.
(the short blocks tend to be relatively bullet proof)
HAM (Len posts here)
Headflow Masters/Audirac (Adrian)
European Motor Works (aka EMW)
If the heads require welding, stick with Len or Adrian, Len if you can afford it.
You probably want just a rebuild/new seats/guides/ex valves, & HD springs.
As a reliability and performance "upgrades" also search on pushrod tube seal, HD 8mm rocker studs (the factory 7mm ones actually suck) and solid rocker spacers.
You must think of this as insurance.
