Yes the nose cone vent is there raised to a breather box.
Somebody told me berg have recommended drilling a breather hole into the bell houseing from inside the gearbox but i have no confermation of that yet!Besides thats a strip down to do cleanly!
questions about 2270
huw'sspeedster
huw'sspeedster
On further investigation the gearbox oil from the sideplate to the drivecup seal leak appears to be migrating rearwards down to the bellhousing looking like a cranckshaft seal leak!
Need to sort things out! Good job really gives me time to sort out real finances for either a daily beetle with super 2litre or a super hero for the speedster!
Thanks for your help!
Huw
Huw
MASSIVE TYPE IV
huw'sspeedster
185/55/15 which look to be 22.5-23 inch diameter! I always thought they looked small, didn't realise they were that small!
Once there worn out i will have to put larger on! Clearances were very tight when the car was built!but suspension adjustments mean i am shore that i can squeeze something taller in there,perhaps a little extra width too!
So a change of gearing will help when i switch to a type4!
Could i reuse the 5 speed kit and quaife lsd with a taller gearstack!
Thanks
Huw
Thanks
Huw
huw'sspeedster
