Great time at BK Dyno day! interesting data within....
MASSIVE TYPE IV
Post by MASSIVE TYPE IV »
It was great to put some screen names together with some faces today at the event! It was also nice to see so many old friends and re hash some TI Vs. TIV rivalries, as always!
I was able to meet a forum member witha TIV powered TIII, I took him for a ride and then tossed him the keys to the Bug for him to drive it back to the event- He was astonished!
The past two years I have taken top HP and Torque at this event, last year I had first and second spots filled, but this year I let the boys play while I did some R&D work on a new engine kit combination utilizing the "New Generation" heads. I set aside the huge numbers to gather some data from a "regular" engine built with 100% off the shelf parts, with the newest 2270 combo we are now offering in kit form.
I have all the datalogging equipment installed in the Blue Bug and witnessed some INCREDIBLE temperatures from this engine on the 2 hour drive to and from the event. I had planned on drag racing the car/engine tomorrow in the Street Car challenge but my dad has his health issues so we decided to stay close to home. The gearing is definately set up to benefit the 1/4 mile and not a Type 4 thats going to be adily driven, with it's 1.04 4th gear. Due to this I was turning roughly 4K RPM at 65 MPH which in 80 degree heat would put a Type 1 to it's knees quick in the oil temp department, the highest oil temp we noted to and from the event was 190F! I only have a very small external cooler, 24 plate Mesa thats 12 years old and probably half filled with crud by now!
The head temps were unreal! The biggest CHT difference that was noted on the 4 hour trip was 23 degrees! The highest CHT I spotted was 332 degrees with most of the time the heads running between 290-310, I only hit the 332 number when pulling a huge hill while accelerating up it.
The most amazing thing is I was still attaining 22 MPG while turning 4K RPM for the entire trip! This is absolutely made possible by the effectiveness of this combo and the effects of the "New Generation" cylinder heads.
Now on to the POWER part of the story...
The dyno operator was a "New Guy" so he had no prior experience with ACVW engines and this morning he really sucked! I was #4 on the dyno and he didn't rev the engine high enough on the first run and acted like he was afraid of breaking something. I told him to stand on it for the second run and he did and got a better reading of 138 HP at 5500RPM and a whopping 147 lb/ft of torque at 3,400 RPM with a wonderful graph that I'll post later. This engine is all about usable power and the plots prove this as the torque curve is damn near flat from 2,500-4,800 RPM!
The engine was a tad bit lean but I didn't figure it was lean enough (13.2:1) to warrant a jet change. Later in the afternoon several of the guys that went earlier in the morning with me and had shabby runs had then re-done, as the dyno operator was doing much better after a few cars hit the roller and he got more used to them.
So we tossed the bug back up and did 3 more runs, 1 with the fan belt, just as it was earlier in the day and then two without the belt. Max HP without the belt ended up being 147 HP at 5,800 RPM and max torque was a whopping 155 lb/ft at 3,500 RPM! Remember that these are RWHP numbers from an engine that was built exactly as it would be from one of my kits, not a single "Trick" was added! Also remember that in the past the 2270 was only good for about 150HP AT THE FLYWHEEL in "kit" form so this new kit and the "New Generation" heads have given us a solid 20% power increase without impacting reliability, or maintainability at all! This kit is running COOLER head and oil temps than any 2270 of this stage of tune ever has before! As a matter of fact this engine made MORE power on the same dyno than the 2316cc Hybrid that was in my 914 at this event last year, and it did this without having to rev 7,500 RPM like the 2316 needed to, this engine was all done by 5,800 RPM which makes it last forever and be easy to drive at the same time!
On the last dyno pull a bunch of the guy wanted to hear the engine rev as high as it could and were giving me a hard time so the owner of the dyno got me out front with him and told ME to tell the operator when to stop rev wise. The engine was all over by 6K making power and all the revs were pretty worthless, but I decided to entartain the crowd a bit because I had already taken this engine well past 7K on my dyno and had plenty of valve control left.... So he keeps revvin, revvin and revvin and I finally hear it run completely out of air and get on the verge of valve float, so I had him kill it at a whopping 7,400 RPM- Remember this is all off the shelf parts, nothing lightened or radical! The crowd was happy..
I'll be doing a lot more test work with this engine in the Blue Bug over the next month or so before I have to change the drag gear box out for my tall geared tranny for the trip cross country to California. I plan on taking it to the local track for the next several test and tune days to get some 1/4 mile logs for HP and torque as well as some temperature data logs. I will also be doing the final testing of the 914 version of the DTM on this engine in the bug so it'll get plenty of time on it very soon both at the track and the street as I'll be driving it 80 miles a day for the next month + from work to home and back everyday.
You'll be seeing A LOT more of this engine very, very soon! :shock: :shock:
So there ya have it a new engine kit has been born, and dyno proven with great results.. It'll be available in about 2 more weeks for purchase through the store as I have to break it all down and come up with the prices of components, don't expect it to be any more expensive than the current 2270 kit, just more powerful.
Can Drive Soon
Re: Great time at BK Dyno day! interesting data within....
Post by Can Drive Soon »
MASSIVE TYPE IV wrote: So he keeps revvin, revvin and revvin and I finally hear it run completely out of air and get on the verge of valve float, so I had him kill it at a whopping 7,400 RPM- Remember this is all off the shelf parts, nothing lightened or radical! The crowd was happy..
I sorta like to hear engines rev their brains out, come to think of it I was revvin the pushmower today. :roll:
But this engine sounds really cool.
MASSIVE TYPE IV
Revvin is for the track... The lower we can make a street engine rev the more fun it is to drive and the better it's behaved when you are out of the throttle....
Plastermaster
Post by Plastermaster »
Good work Jake!. I guess I'll have to find a 95% efficient tranny. :)
Those oil temps are amazing. What do you attribute it to? I can only think that some how the friction is minimal. Head temps have a little effect on the oil temps but Iknow my engine can cruise at 325-350 but at 4K the oil temps would be up close to 230 with a 72 plate cooler.
On the head temps how cold can you run before efficiency suffers?
I know you wont want to get to detailed, but how close is this one to the Hot VW build?
Ron
MASSIVE TYPE IV
Efficiency 100%. This engine has no coatings, no exotic components and no altered clearances. The "New Generation" heads are da bomb!
The effects of the heads are attributing to it no doubt. I have NEVER had a 2270 engine run this cool in this car, never!
At this point the heads are the only thing I can attribute it to. I'll do more decyphering of the data as time goes on and throw some changes at the engine to see what trends occur and see what happens.....
Generally the efficiency is best with a head temp between 300-325
We'll see when the data is released on the Hot VWs build up engine... :-)
RG64
Post by RG64 »
This is getting very interesting, that's what R&D is all about. Awesome job Jake an Len!!! Keep it coming.
Rick
MASSIVE TYPE IV
As long as the customers keep buying, we'll keep developing!
I am lookng at purchasing my own cam grinding equipment so we can further camshaft development even further by being able to make cam changes in house....
Thats the next step!
HAM Inc
Post by HAM Inc »
When the ability to do in house cam grinding occurs things are going to get even more interesting... fast!
Wally
Post by Wally »
Very exiting results, especially on the head temps!
What exhaust were you using?
Tnx,
Walter
MASSIVE TYPE IV
Exhaust was a 1-5/8" A-1 arrangement with 2.5" magnaflow muffler..
R2.0
Post by R2.0 »
Another guess on the new heads:
Oval port heads plunge cut with a cutter the diameter of a single port intake, and then step cut to take the SP copper gasket. This is from hints about new shapes, new exh port sealing methods, and new stubs. Of course, it's been 10+ years since I've messed w. single ports, so I don't remember the diameter that well.
I know Jake won't let the cat out of the bag in deference to HVW, but it's a fun game.
R2.0
RG64
Post by RG64 »
Jake, what size carbs did you use in this motor and did you see any big changes in jetting from your past combo?
Rick
huw'sspeedster
Post by huw'sspeedster »
180bhp at the flywheel from a 2270kit with carbs? What will that do with efi and crank trigger i wonder? What was the with cooling power figures at the wheels?
MASSIVE TYPE IV
I would not expect any more HP from this combo with EFI Vs Carbs, BUT you will see a boost in torque and across a flatter curve with EFI. I have 3 of these engines coming up very soon in an engine batch and all of them use EFI so we'll have data in jiffy.
The carbs used were Weber 44s with stock vents and the only changes made to them was a 140 main jet instead of the 135 that we typically see with the previous combos.
type11969
Post by type11969 »
So are these new heads available for purchase seperately? Or only in kit form?
Locked
