944 rears with Ghia disk up front
bt
Post by bt »
Anybody running 944 rear brakes with Ghia disk up front? I have a 944 front and rear set up but I will need to run turbo 4pots up front if I want to use my dropped spindles. I dont need that kind of braking power. Nor do I want to spend more money.
If I used a proportion valve, I think it would work. Anyone done this yet?
Thanks
Victor H
Post by Victor H »
I have 944 single piston sliding calipers on the rear. With a 21mm bus MC I have too much rear brake bias even with 4 piston (Boxster) fronts. I had to install a brake proprotioning valve and it works great (just got it today). Oddly, it was less of a problem, but still not optimal with Ghia discs in front.
