Oil temp issue
type11969
Post by type11969 »
Okay, well I'll go through the engine, timing, etc (I have the full adjustment kit for the Mallory, just haven't had a chance to your recommended specs), replace the adjusters, and give it a go again with 10w/30. If I am still having the same issue, I'll swap out for some 20W/50 and report back with the results.
udidwht, I am using a VDO temp gauge with a dipstick sender. I've checked the readings against boiling water, so it is fairly accurate.
MASSIVE TYPE IV
Post by MASSIVE TYPE IV »
Don't worry about redialing the entire dizzy... Just back the total timing down 2 degrees and run it for comparison, you'll always be above 3K RPM at cruise so it'll give you direct results with less work exerted..
The 86 is a cam that doesn't like timing very much.
type11969
Post by type11969 »
I've got some time before the adjusters get here, so I might as well take advantage of it.
MASSIVE TYPE IV
The lazy valve timing of the lash could be giving you some of the issues, especially with the straight pattern cam..
type11969
Post by type11969 »
I hope so. It was interesting looking at some of the adjusters that had been in the engine for the past 500 or so miles, I compared them to one out of a 1.7 that I am sure had many a mile on it. The wear on the contact area of each adjuster was similar. Defintely a believer in the 911 adjusters now for any cam over stock!
MASSIVE TYPE IV
Told ya so..
Plus new adjusters SUCK! The hardness is really crappy.
Locked
