Ground clearance, deep sumps.
shambly
Post by shambly »
Jake,
How much ground clearance would I loose with one of your deep sumps?
Currently the sump sits 5" off the ground (lowest point on case 4 3/4", exhaust 5 1/4") and i'm concerned about loosing ground clearance for our speed hump inhabited local roads (but equally concerned about loosing oil pressure on a track).
My current thought is a 2 qt accusump with an EPC (20-25psi version?) plus a tuna can or deep-sump depending on which is less prone.
I think on the Le Mans circuit I suffered with both cornering g-force (accelerating around sweeping left hander) and pumping the sump dry (changing up from 2nd gear to 3rd gear at 6000rpm, coming out of the S's onto the grandstand straight :shock: )
Are the BAS "tuna-cans" sold in Europe the same as those refered to on STF?
Thanks,
Simon
Wally
Post by Wally »
I have a BAS 'tunacan', a 914 sump-plate (perforated under the pushrod tube exits) and a stock oil pump and had no issues with oil pressure after my track day last thursday:
And believe me, we were flying and exiting tight corners in second gear at 6200 to third :D
Walter
Kelley
Post by Kelley »
Nice pic :D
shambly
Post by shambly »
Wally wrote:I have a BAS 'tunacan', a 914 sump-plate (perforated under the pushrod tube exits) and a stock oil pump and had no issues with oil pressure after my track day last thursday:
Walter
Walter,
Nice picture! How deep is the tunacan and how far off the ground is it when installed in your car?
Thanks,
Simon
Wally
Post by Wally »
Its 3 cm's lower on the sump (1 inch = 2.5 cm) and you will never hit the ground with that. Mostly also because it is rather close to the shock mountings (closest to the ground normally) :wink:
The even nicer ones are made from alu and are ribbed for a tad extra bit of oil cooling (Remmele and Gerd Weiser e.a. IIRC)
shambly
Post by shambly »
Yes, shock mountings are 4", so that would make the sump then about 5mm below the suspension damper mounts.
Thanks Walter
Locked
