The NEW LE 220 Turbo Head!!! Pics within!!
- wrenchnride247
type3
MASSIVE TYPE IV
we have gotten away from the square ports for developments. Len found inconsistent ports that created issues...Steve Arndt wrote:I thought that you were looking at using the square port casting flange on the exhaust because of more sealing area. Is that only when dealing w/ a non welded head for a more mild application?
Just because we are working with something does not mean we will be staying with it-
Len, The Mighty Spyder made 257 HP, your dyslexia is in full force today!!LOL
HAM Inc
The sq. ports are a lousy choice for a turbo powerplant. A couple of reasons for this. One, by the time we open the port, the port wall gets pretty thin, this leads to a poor seal, and cracks in the port wall as the extra length of the sq. port sees very little cooling airflow. The issue Jake was referring to about inconsistencies is related to the casting seam that runs down the middle of the ex. port. Never knew what to expect from the OUTSIDE of the port. Some were nice and smooth, others were sharp and rough, which served as some pretty serious stress risers. Not a good situation for an aircooled ex. port. We got some fabulous results from our sq. port r&d, but I am now focusing all of my ex. development on the oval based heads.
Just a little aside while we are on the subject of exhaust. I have not seen any need to move beyond the oval port on displacements up to 2316 N.A. The flow balance of the heads is readily maintained for every application Jake has thrown at me to date. It's important to keep in mind that flow %'s over 75% on a N.A. apllication suck the low-end and mid-range torque out of an engine, any engine. The latest NHRA Pro-Stock engines are running flow %'s in the low to mid 60"s. I have prepped A/X heads with 65% and gotten reports of overwhelming, neck snapping response and acceleration.
Jake after I made that post this morning it dawned on me that the HP I posted was high. And my math was off too!
MASSIVE TYPE IV
MASSIVE TYPE IV
- Can Drive Soon
I can build you a furnaceMASSIVE TYPE IV wrote:If the AMC head castings become unavailable and we were forced to make our own castings we certainly would, but I do not see it happening.
Now if we could only find a fuel that puts out the same or more energy, starts in the cold (no straight ethanol) and burns cooler......MASSIVE TYPE IV wrote:Getting all that heat out of the exhaust port is certain to help with the heat that is soaked into the head in that area- heat that isn't soaked doesn't need to be dissipated...
type3
MASSIVE TYPE IV
MASSIVE TYPE IV
- Ephry73
type3
HAM Inc
Ephry I've seen a solid 10% improvement in flow going to a properly designed D-Port with a given valve size.
Type3 I am so glad you love your new heads! I appreciate the patience you displayed while these bad boys were being developed. You definitely have a better product as a result.
I would love to take the credit for the beautiful TIG work on the stubs, but that is the handi work of my neighbor Chuck Manning of Tarmac Motorsports. I designed the stubs, but didn't have the time build them so I enlisted Chuck. He is a very gifted fabricator and his custom sheet metal work and exhaust systems are beautiful. The aircooled world will be hearing a lot more out of Chuck in the coming months. He is an integral part in the H.A.M./R.A.T. F-Prod 914 currently under construction for the 2007 season.
