Anyone know what the wall thickness of the Manton CrMo PRs are. Mine have been assembled and I was looking to cut a bit off next to the tip and shorten.
Something went wacky when I was calculating P.R. length, looks like I have 0.5mm / 0.020" too much diff between Int & Ex for the split duration cam. I have dremel cut off blades of the same thikness and with a jig set up can do the job, just not sure how far to cut before its ready to pound the tip deeper.
CrMo Pushrod wall thickness
Oil Phil-M
