welded diff
HRD 68B
welded diff
Post by HRD 68B »
hey guys how bad does a welded diff and close ratio 3rd and 4th make a road car, can it be liveable ? or will it just handle like a pig. i wouldnt need to cruze about 60mph with a short fourth it might be liveable. anyway guys what do you reckon
cheers brenton
Marc
Post by Marc »
I strongly recommend against it..the welded differential on the street, anyway. There are many possible "close ratio" 3rd and 4th gears, what's the numbers you have in mind? Something not too extreme like a 1.04 or 1.125 would be tolerable, but there are 4th gears out there that are lower than that (some lower than a stock 3rd)...would you want to cruise the highway in third?
http://www.shoptalkforums.com/viewtopic.php?t=108804
gcorrado
Post by gcorrado »
like marc said, a welded diff or spool is a serious no-no on the street. it's probably about as safe as driving in reverse all day. sure, you could do it in an emergency, but it's a profoundly bad idea to do regularly, or at any speed, or with traffic around.
on in-town roads that are 45mph or less, a close ratio box is no trouble. more than that, like marc said, all depends on *how* close and how *short* you want your engine's life to be.
HRD 68B
Post by HRD 68B »
yeah so i suppose the gearbox would be a drag only one. i know what the 3rd and 4th gear ratios are but not what the r&p is so its a bit of a guessing game. 3rd 1.5 and 4th 1.3 so it would be a very low 3rd and 4th with any r&p . im just trying to find out if it is worth me buying it off a friend. it has supposed to have been rebuilt by PDS in the UK. ive got a 2276 im building up and wanted a stronger gearbox. should i look else where or buy this and try out the gears and then if i want to run it on the street change to a lsd? its only $500 Australia. what do you guys reckon ?
cheers brenton
Brent Bousman
Post by Brent Bousman »
Forget the locker and get a LSD.
To figure out the R&P with the trans still in the car try this:
Jack one rear wheel off the ground and block the other one. Put it in 2nd and turn the engine CW by hand to TDC, then mark the free tire and turn the engine over until the tire turns two full turns. If it takes 8 rotations of the engine, it's a 3.875 R&P; if 8½, it's a 4.125.
If it's a 3.875, next question is the 4th ratio. Repeat the process in 4th, if it takes just under 3½ engine rotations for 2 turns of the tire it's the .88, if just over it's the .93
Ozzie
Post by Ozzie »
Brent Bousman wrote:Forget the locker and get a LSD.
Brent, You rock. Thanks!
Ben Franklin
gcorrado
Post by gcorrado »
Brent Bousman wrote: To figure out the R&P with the trans still in the car try this:
that, my friend, is a very cool trick.
Marc
Post by Marc »
gcorrado
Post by gcorrado »
Marc wrote:But hardly news.
Nothing's news to you, Marc! I don't know how all that stuff fits in your head, seriously. Thanks for the the pointer to additional info.
