Still Looking for a test light bulb
- david58
Last year I bought a test light, that I have either lost or misplaced. It had a fuse type bulb in it with two filaments one filament was red and the other was green. If you hooked it to ground the red filament would light if you probed a power source. If you hooked it to power the green filament would light up if you probed a ground. Well I have searched till I am blue in the face and can't find anyone who sells the bulbs. I bought it by accident, but now have a use for the two filament bulbs. Any info on a source for the bulbs would be greatly appreciated.
2088 bob
david with out wanting to sound like smartass two words GOOD luck
can you snap a pic of this tester you have for me very curious if you should ever find the tester again
- david58
No, 2088 bob it does exist really. I dropped the test light the bulb blew, I have since lost the bulb carrying it in my pocket looking for a replacement. The part store where i bought it went out of business and I can't find the test light to see what brand it was. I probably have at least 20 test lights I moved my shop and a lot of my tools are packed away in boxes. When I first used it I didn't like it the bulb lite up red when looking for power. Then one day I was checking a electronic fuel pump for power and ground when I hooked the test light to power and checked the ground circuit it lite up green I was in shock. I will find the source and share it when I do.2088 bob wrote:david with out wanting to sound like smartass two words GOOD luck
can you snap a pic of this tester you have me very curious if you should ever find the tester
- david58
Product Description
- Helps to quickly identify if there is voltage present on wiring and circuits - Ergonomic grip design with 6-foot test leads - Transparent handle shows bright LEDs to identify connections: - Green = Ground Present - Red = Voltage Present
See I have Good Luck Hot, humid air is less dense than cooler, drier air. This can allow a golf ball to fly through the air with greater ease, as there won't be as much resistance on the ball.
- david58
Thank you 2088bob I searched for a week before posting and just didn't type in the right info the one I found probably isn't the same brand as the one I bought. Even though it does the same thing. I have an idea I want to patent with this test light, and like you I was in disbelief when it changed colors.
- MedicTed
The best test lights are simple. I use a bacl up light socket that can be bought in any FLAPS as replacement, with a wire attached to the body of the socket as the ground. Just use crimp connecters to make the wires longer and to connect whatever type of contacts you want (alligator clips, probes, etc). They are cheap, the bulbs are easily replaced and easy to identify.
- david58
- david58
Just got my test lights. These aren't the same as the one a was looking for. They do the same thing though. The one I had used a 2 color tube type bulb. I don't think the led are replacable in these. If anyone finds the bulbs I am looking for please post a link.David58bug wrote:I ordered three that way maybe I can find one when I need it.2088 bob wrote:dave i have just gone ahead and ordered one
