I was tuning my motor today when the negative battery connector got knocked loose for a moment (obviously it wasn't tightened well enough). Immediately after that I noticed that the tach stopped working.
I have a 356 tach in my VW and now the needle is pegged out (@ max RPM) and stuck in that position whether the motor is on or off.
Any ideas - did I fry the tach somehow, or short something out?
Fried Tach?
VUU
Yeah, I did tap it and I even disconnected it, but to no avail - that needle is stuck.
Silly mistake - I'd just removed and then re-installed the battery and I thought I tightened both connectors. I have an alternator rather than a generator on this particular motor, but apparently the voltage irregularity was still enough to damage the tach.
- MNAirHead
VUU
Thanks for the help and concern, Tim.
I'm happy to report a happy ending to my story: I pulled into my garage last night and when I glanced over at the VW I noticed that the tach needle had returned to its proper position. I then started the car and the tach worked properly. Apparently the needle was simply stuck. I did tap on the gauge the night before, but to no avail. It seems the needle just needed to unstick itself. Thank the Lord for small miracles!
