http://i77.photobucket.com/albums/j47/k ... CN2757.jpg
I don't remember where I ordered these from. One can see the holes that have been drilled into the large piece. The calalog describes it as a "Bolt on" item. I don't see how to approach this. The smaller piece has nuts for the fender bolts. Do I put bolts through the nuts then lay the large piece behind it with the holes aligned with nuts, then weld it all to the back of the luggage tray?
TIA,
Kevin
