SAW adjustable spring plates for IRS
1303wasserbug
Post by 1303wasserbug »
i have fitted saw adjustable spring plates to my 1303, now the outer spring plate tube rubs on the gromet retaining plate. i have fitted spacers that were included in the kit to space retainer plate out as spring plates are thicker but now i'm thinging about taking them out. anyone else fitted these and can offer advice? cheers
Southernbug
Post by Southernbug »
I recently installed SAW IRS adjustable spring plates on my 74 standard. Do you have any pictures to show your problem?
1303wasserbug
my problem is the spring plate tube is rubbing on the retainer. did you use the spacers to move retainer plate out further than stock? crap pic sorry
Southernbug
I did use the spacers that came with the SAW adjustable spring plates.
Good luck!
1303wasserbug
ok, so i have new polly bushes as well so thet arn't the problem. i will put less of a spacer on to see if that tightens it all up.
