Buggy Turbo 2,1 DJ *Bugun 09*
Rydh
Post by Rydh »
1 HOT VW GP wrote:Hi Rydh
The Quality of your work are Excellent
A question or 2 if I may
I dont see you mentioned after market EFI are you still using the VW DJ system :?:
Thanks
Pierre
Tanks!
I use a slightly modified DJ system, larger injectors volvo 218cc in the custom fuelrails, a 1:1,2 progressive Fuelpressureregulator from malpassi.
I have adjusted the spring in the stock AFM by tension it five clicks and i run about 4,5bars of fuelpressure.
I runs a bit to ritch when its cold but after just 500meters driving it works fine.
The new best ET from last week is 13.19s on 402m and 8.29 on 201m. This time drove on M/T et streets
//Rydh
Flagbuggy
Post by Flagbuggy »
That is excellent for what you got there
This is my buggy 2.3L type 4 have done a 11.1@198km/h 1/4mile best in 1999
sold the motor and standing ever since
Your setup sounds attractive and cheap :!:
2.4 Type 4 Turbo Flag buggy 11.1 sec
13BT 240KW Cabriolet Bug
66 Freurwagon Long term project
66 Squareback Sunroof Project
2000 NB VR6 Turbo Project
84 DC 1.9WBX
86 Kombi 2.1 WBX
Flagbuggy
Post by Flagbuggy »
Hi Rydh
What turbo from wich Volvo did you use
What do you think will be the benefit advantage of programmable injection timing and fuel ratios over the stock system :?:
Thanks
Pierre
84 DC 1.9WBX
86 Kombi 2.1 WBX
Rydh
Post by Rydh »
Thanks
Pierre
Nice buggy you´ve got there!
The turbo is a Mitsubishi TD04-13c from a Volvo 940 Turbo, but any 13c, 15g 16t fron 850turbo (ore another garret T25 etc)would work just as fine i guess.
I was thinking of installing a vems ore autronic system and larger injectors and run it on E85 ethanol (easily available in sweden) but since this system works so nice I´ve put those plans asside.
whith the stock DJ you must run high impedance injectors thow, larger injectors are a bit more common in tho low impedance type.
I don´t think that my 100% stock never opened engine(ore clutch and stock typ1 tranny) can tacke mutch more power than the 175 it´s putting out now otherwise Ethanol and a standalone system would probably give mee 200+ hp with the same compressionratio.
Probably this winter the buggy will rest since I´m in the process of buying a house
//Rydh
Flagbuggy
Post by Flagbuggy »
`s up Rydh
You say high impedience what is the ohms for high and for low
Do you know the size of the std Injectors for DJ
Rydh
Post by Rydh »
1 HOT VW GP wrote:`s up Rydh
Low is about 2ohms and high 14 from what i remember
Ste stock DJ injectors are 175cc and my new volvo ones is 218cc
Here is a complete list:
http://users.erols.com/srweiss/tableifc.htm#BOSCH
//Rydh
Flagbuggy
Post by Flagbuggy »
one more thing the head gaskets do you use the ones in the gasket set those ally looking things and what do you torq the heads to
is there something els I can use :?:
Thanks for all the help :D
Pierre
Rydh
Post by Rydh »
1 HOT VW GP wrote:one more thing the head gaskets do you use the ones in the gasket set those ally looking things and what do you torq the heads to
Pierre
Actually my engine has never been opened så its the original ones i guess :oops:
//Rydh
Flagbuggy
Post by Flagbuggy »
Sjoe Unbelievable
Thanks
Pierre
84 DC 1.9WBX
86 Kombi 2.1 WBX
Rydh
Post by Rydh »
Some Pics from Bugrun 2008!
No further mods to the car ore engine exept för the tires, 12.96s och the quarter mile with a 100% stock 2,1DJ engineblock and turbo (and stock 1303s tranny)
//Rydh
Rydh
Post by Rydh »
A movie from Bugrun -08
http://www.garaget.org/video/51hnm754klvz
(me and fastback)
//Rydh
fastback
Post by fastback »
:D nice video and thx for a great weekend!
DORIGTT
Post by DORIGTT »
Pretty cool fellas!
Rydh
Post by Rydh »
It works great in the ice aswell! 8)
And a movie:
http://www.youtube.com/watch?v=Vr9R2rZ56l4
At 2:11 there is some Buggy action!
//Rydh
Flagbuggy
Post by Flagbuggy »
Hi Rydh good to see the buggy still going strong
In the prosess of getting all the goodies together for a friends 2.1 turbo :D
Keep well
84 DC 1.9WBX
86 Kombi 2.1 WBX
