Hi, every one. please help
I want to set up my 1302 bug for daily drive ( 80-100 km/day hill and hiway, every day 2500-3500 rpm is mostly use)
I think only 100 hp with 1584 is enough for me, don't want to increase cc to achive, i need low end torque for hill clamp.
where should i start.
I plan to use small japan supercharge that i have (aisin amr500 from nissan march) with my STD1584 (rise up cr to 9.2:1 use LPG only for two years), now i take engine apart because lifter fail. so this is good time to set up.
any one try?
will it work with my propose?
thanks
Small boost with superchareger
- Buggin_74
ur probably aiming abit high at 100hp from a amr300 on a stock 1600
that CR is abit to high
ive got a 4agze blower on my stock 1600 (7.5CR) which is a 1200cc blower, urs is only 300cc and its putting 84hp at the wheels at 6psi
even with 7.5CR i occasionally get ping
i havent dyno'd it since upping to 10psi
there was a bug getting around here that sold on ebay awhile back that has an amr300 on a stock 1500sp with a 2" SU
1974 Germanlook 1303 Suba-Beetle
Subaru EJ25 Boost R 17", 4 Wheel discs, Topline suspension and A/C
Thanks,
from spec. this arm500 have 500cc/rev. ( arm300 have 300cc/rev )
May i ask for ur belt ratio with ur SC12,
from the calculate number, I got 2.2:1 for 6 psi, is it correct?
do i need to reduce ratio to compensate heat expansion?
STD. part can up boot to 10 psi!?
how ?
I use with LPG only, before this i set to 10.2:1 run daily for a year before lifter fail, never ping with correct timming ( 094dis. 13 deg@1000 rpm
but if i set to 15-18 some ping in mid rpm. but it pull stronger.?)
Im not so sure about 9.2:1 with 6+ psi
with octain 116-120 of LPG. this will work?
have any one try high cr with boost?
thanks in adv.
thanks in adv.
- Buggin_74
hi,
sorry i was half asleep when i read that i though u had a 300 not a 500
currently mines running at 1.23:1 and can hit 10psi in 1st and 2nd gear but only 8 in 3rd and 4th
i havent had any real dramas with heat but i am working on setting up a water injection system
ive got no real exp with running LPG
i just run mine on 95 premuim which i think is 92 in the US
if u want any more info on my setup theres a full thread on it at
http://forums.aussieveedubbers.com/view ... ?tid=65678
or see what she can do in my youtube vids
http://www.youtube.com/watch?v=eNWu_2XEBiY
