vavagon rear camber?
My 83 Westy rear wheels have a fairly serious tilt. The top of the wheel tilts in and the bottom out, about an inch at the tread of the tire. I've been told this is to improve handling, though I don't seem to see the same toeing on other vanagons. There seems to be no real abnormal tire wear, 10 000 kilometers into a fresh set of 6 ply Michelins, (though all 4 tires seem very slightly rounded, mostly I think because of old suspension). Any advice, opinions?
We had the same problem with tire wear, but aligning the suspension made a big improvement. We had 1 deg of negative caster at the rear, and readjusting it to 0 degrees cured the problem. We also had some toe out at the front that was adjusted to a bit toe in. Realignment made it very stable and relaxing to drive, even at high speeds.
This is a problem that afflicts every Bay window Bus, and yours too. The grommets around your torsion bars at the spring plates are completely shot and need replacement. You can confirm this by looking at the torsion bar as it exits from the spring plate cover The tube supporting the torsion bar will be all the way up in the hole, usually rubbing against the torsion bar cover.
Getting an alignment while these bushings are shot is wasting your $$$.
The bushings probably need to be checked but no torsion bars on his Wedgie. A worthy alignment shop will check for play in the various joints before they mess with any settings. After all, why work for $50 (alignment only) when you can work for $500 (alignment + repair)?Bruce2 wrote:This is a problem that afflicts every Bay window Bus, and yours too. The grommets around your torsion bars at the spring plates are completely shot and need replacement. You can confirm this by looking at the torsion bar as it exits from the spring plate cover The tube supporting the torsion bar will be all the way up in the hole, usually rubbing against the torsion bar cover.
its camber doesn't change much loaded or not. the suspension actually sit about proper hight, friends with Vanagons say my van looks "big" because it sits at a tall height. When I do the "shock test" (Push down, and see if the van "bounce" or just comes back up) its doesn't bounce, so I think the shocks are reasonable. As I said, the camber isn't a new thing, its always been like that, passed safety like that, and I've put 10 000+ kms on her since. I'll get her looked at before I put her away for the winter I guess.
