68 bug
Does anyone know of hand how many degree's = how many inches of drop or lift? The adjusters we're using are the weld in ones from CB. Thanks
Beam adjuster - degree question
- turbobaja
Just mock it up. Slide a trailing arm into the beam and set your angle finder on top of it. Hold a tape measure/ruler from the floor up to the end of the arm and measure how far the arm moves as you watch the degree increase and decrease.
Then you'll know what degree to weld it at to get the lift or drop you need.
Karl
Karl
