Who can speak hypotheticaly with me?
DORIGTT
Post by DORIGTT »
If you were building a high performance WBX in trying to get 250-300hp and torque reliably, what would you put in it? Let's either supercharge it or turbocharge it.
How would you build it?
What size would you make it?
51MAN
Post by 51MAN »
I think I would hypothetically think about using a subaru turbo motor..........
unless you have very deep pockets........
2.5L, small low pressure turbo (or poss a supercharger) big intercooler, megasquirt etc, big oil cooler, lightweight lifters... really its only a step up from what I want to biuld.. I want good solid reliable power and low end torque........ it would be quite easy to do a 10k mile engine, much harder to make it last 50k or 100k......... I want mine to do at least 50k before ANY work....... 75-100k would be much better........
MNAirHead
Post by MNAirHead »
Suby Ej engine is your best suggestion.... or induction on a Mazda Rotary
DORIGTT
Post by DORIGTT »
Thanks for the suggestions.
Like many of the enthusiasts here who get a bee in their bonnet about something, I would like to explore what options exist for me in the VW watercooled family. I've considered the Scooby route but I like the idea of urinating up a rope at times :lol:
Any other suggestions for a WBX build up?
Unkl Ian
Post by Unkl Ian »
Street motor:
EFI, Eaton blower, intercooler, "small" bore long stroke.
OR
twin charged, using an Eaton blower and turbo with intercooler.
Type 4 main crank, maybe larger.
Dual plugs per cylinder.
Two injectors per cyl.
Water cooled helps control detonation.
Subi' motors have 5 main bearings, which would help long term reliability.
DORIGTT
Post by DORIGTT »
Where can I get info on the twin charger concept? I unfortunately don't have that kind of 'in' at work.
carsten bb
2.5l
Post by carsten bb »
I would do a 76.4 x101.6 wasser.
Stock balanced crank.
good H beam rods.
101.6 dished pistons
custom sleeves.
headwork as you can afford.
mildish cam
pauter 1.3
14-30psi boost.
efi intercooled.
300-550hp+.
you don't need twin sparks or twin injctors.
bullet proof street engine.
Unkl Ian
Post by Unkl Ian »
DORIGTT wrote:Where can I get info on the twin charger concept?
http://www.eng-tips.com/viewthread.cfm?qid=174690
http://www.theturboforums.com/smf/index ... ic=55371.0
That should get you started.
Definitely need an intercooler, and fuel injection.
Two injectors per cyl are easy to stage with megasquirt.
One injector handles low boost operation, the second comes
in as boost increases.
Two plugs per cyl, requires less advance to make power,
which reduces the likelihood of detonation.
Joe vw
Post by Joe vw »
GoWesty 96mm pistons, quality I-beam rods and stock crank 5 pins added. Type1 solid lifters with turbo cam. Flow benched heads w/larger valves no headgaskets.
1 5/8 exhaust hybrid turbo, large intercooler and programmable injection.
This can be accomplished with the stock or close to stock displacement with not much problem.
Keeping the bore smaller saves money and reliability at the head seal. My plan is to build this engine eventually.
Others here have boosted stock engines to 250hp. Good heads will allow you to do it with less boost.
fastback
Post by fastback »
NOt totaly hi performance but 300HP on E-85 at 15PSI
Stock crank and rods.'new rodbolts' (yes they take it)
Go westy 96mm forged wisecos/and cyl(even stock MV 94 will do)
mildly ported stock heads
web 86B on 112lobes + 29mm bigfoot wbx/type 4 lifters
T3/t4 hybrid turbo
megasquirt'n EDIS
Water to air intercooler
DORIGTT
Post by DORIGTT »
Why I-beam vs. H-beam rods?
That website is awesome! All those people touching calculators and wrenches at the same time...chilling.
Wouldn't a 1.5" system be 'better' for that size engine over a 1.625"?
DORIGTT
Post by DORIGTT »
Fastback,
Your setup is 'not totally high performance' like water (stock 160cc = 53hp) is to Vodka (you're at what 320+hp?).... please take your seat now. :lol:
51MAN
Post by 51MAN »
How much are you prepared to spend??? thats prob the biggest factor and all I can see is....... $$$$........ :wink:
