How to Stop Fuel fitting from Falling out of Solex carbs
Here's the place to start. Introduce yourself and your ride.
Let's see your fixes.
Glenn wrote:
Mikeflys wrote:The brass nipple on the carb for the fuel line has fallen out.
jrandy
Post by jrandy »
I take the tops off and tap them for 1/4in pipe fittings.
Actually, some of the later carbs I have tried to remove the stock fittings and they would not come out.
Did somebody address this problem at some point?
jrandy wrote:I take the tops off and tap them for 1/4in pipe fittings.
Is any drilling required before tapping them?
jrandy
Post by jrandy »
Yes, it was necessary to drill the top out to fit the tap for the pipe fitting.
I figure once the fit between the tube and the top is eroded to the point of falling apart I am willing to take the chance with drilling the top.
I put the top in a vice with some softer material on the vice jaws to keep from galling the mating surface for the top.
The aluminum is very soft and the drill will bite right into it if you are not careful and/or use some sort of stop for the drill bit.
The boss for the brass fitting is pretty thin, but there is enough material there to do the deal if you are careful.
fusername
Post by fusername »
I am actually going to attempt this this weekend, if my bus doesn't run me over first. The nice thing about NPT taps, is that they have the proper drill size stamped right on em.
Bugfuel wrote:Hey.. here's a picture of knurling the fitting:
Press hard on the file :)
Jan
aussiebug
Post by aussiebug »
I knurl them as shown in the pic above, but I prefer to use the edge of a flat file with single cut teeth, and run the file at 90 degrees to the pipe so you get just about 1/4 inch of knurled surface, a little behind the end of the pipe which will be in the hole. This methods produces a set of single ridges running parallel around the pipe (like gear teeth), so the inside of the carby top does not get chewed out by multiple "teeth" when the pipe it tapped back in to the hole.
The "bottom" end of the pipe must remain smooth as this is what seals the pipe in the hole and stops fuel leaking out.
I've never had one fall out or leak after using this simple process.
Oh - and never put a fuel filter in the line between pump and carby - this increases the likelihood of that brass pipe falling out - extra weight vibrating the fuel line and carby inlet pipe. The fuel filter should be before the fuel pump so both the pump and carby get nice clean fuel.
Regards
Rob
Rob and Dave's aircooled VW pages
Repairs and Maintenance for the home mechanic
www.vw-resource.com
Bookwus
Post by Bookwus »
And to add just a bit to what Rob had to say.............
I also follow the same routine advocated by Rob. Additionally I also coat the knurled end with just a bit of JB Quickweld when I tap it into place. On top of that I use the wire restraint also.
This may seem like a bit of overkill but, then again, I've seen a couple of engine fires up close. I'll go with the overkill any day.
Have an AutoStick?
Visit http://www.auto-stick.com
volkenstein
Post by volkenstein »
Drill and tap for 5/16 UNF, machine up a fitting for me :
Volkenstein
sideshow
Post by sideshow »
My method, just make a pseudo strain relief to keep both the carb and fuel pump barbs from being able to escape.
sideshow wrote:My method, just make a pseudo strain relief to keep both the carb and fuel pump barbs from being able to escape.
I agree with Piledriver you still need hose clamps.
You stated in another thread that for your era car they didn't come with hose clamps from the factory. Ever wonder why a car burned? Clamps might have saved a slew of VW's.
sideshow
Post by sideshow »
The problem I'm addressing keeping the barbs from falling out. A separate issue could be made that the stock cloth braided fuel line does not benefit from have some worm drive clamp crushing them.
And no I don't wonder why a car burns, I'm certain that clamps do not fix stupid, but if I had to bet;
  • A pressed in barb, that is allowed to fall out
    Some expert using ¼ inch SAE line over a much smaller barb and claims a clamp “will hold that”
    Electric fuel pumps that continue to run (no factory like shut off) when engine stalls
    Pure neglect, as in no line should be moist, external filters should not crack, run away vibration, or something caught in say a fan belt
Maybe should say that I only use factory approved hose clamps, you know the ones used in millions of cars sold all across the planet that didn't burst into flames.
A GOOD clamp like one of the spring loaded ones (very annoying but work great, whatever they are called) or a proper EFI clamp will not eat the hose.
I understand what you are saying, but still disagree somewhat.
The optimal combination would be a screw in fitting and properly strain relieved line.
Also, Use SAER9/11 hose (AKA EFI hose) rather than the R7 "not for fuel injection" hose... Yes, it costs ~ double, but it won't dry rot in 6 months. Should last many years with proper clamps.
aussiebug
Post by aussiebug »
David 58 and Piledriver say you MUST use clamps.
But in fact the cotton covered 5.5mm VW fuel hose does not need clamps - the cotton covering does that for you.
Just try pulling a fuel line off without twisting as you do. The braided cotton covering works like a Chinese finger trap and tightens when it's pulled.
There is nothing wrong with using clamps too, but they are not really necessary if you use the correct fuel line.
VW made 22 million bugs which did not use clamps on the hoses, and they were/are GOOD engineers.
The lack of clamps does not cause fuel fires - engine fires are almost invariably a result of the brass inlet spigot falling out of the top of the carby with the fuel line still attached, and as described above there are various good methods of preventing this happening. The other main cause is the fuel line itself not being replaced after a reasonable time so it cracks under the cotton coveriing, or starts to split at the ends, and sprays fuel.
One problem which does exists now which did not exist a few years ago is the quality of the "genuine" VW fuel hose. It's often very thin walled and rots/cracks in a few months. My local VW supplier now gets fuel hose for early BMWs which is exactly the same as the 5.5mm VW hose of old, and this stuff is much thicker walled, better quality rubber, and lasts like the original VW fuel hose did - several years at least.
Regards
Rob
www.vw-resource.com
