decisions ?! flywheel or pulley trigger?
WickedWagens
Re: decisions ?! flywheel or pulley trigger?
Post by WickedWagens »
You could do the crank trigger behind the front pulley so you don't see it. I think that this turned out great and I will probably be doing this in the future.
http://shoptalkforums.com/viewtopic.php ... 2&start=30
Eaallred
Post by Eaallred »
WickedWagens wrote:You could do the crank trigger behind the front pulley so you don't see it. I think that this turned out great and I will probably be doing this in the future.
WOW, that is awesome!
seb
Post by seb »
ive decided to get the pulley machined. Il hide the sensor as best i can.
Cheers guys for the info its much appreciated.
:D
Turbinepowered
Post by Turbinepowered »
Oh man, the flywheel trigger is sweet.
Guessing the drawback there is you get no sensor adjustment, it all has to be "soft" when you change the timing, through programming?
I may do flywheel triggering for the Beetle... and I'm really thinking about doing it for the FOX now. :D Bore a hole in the bellhousing, make a threaded plug, drill holes perpendicular to the flywheel's axis rather than parallel to it?
seb
Post by seb »
ok so currently machining my pulley.
im having the sensor at tdc+20' clockwise missing tooth at 70' or.... clockwise 90' tooth +1 tooth, missing tooth at 110.
woot
Vee Dub Nut
Post by Vee Dub Nut »
Nice!
yvre
Post by yvre »
Can you balance it back afterwards?
seb
Post by seb »
yeah il have to get it balanced again but i think you can be able to work out the weight of the missing tooth and work out its distance from the center then drill the opposite holes accordingly, obviously there have to slightly deeper due to the holes being closer to the center than the missing tooth.
easier just to get it balanced i think lol
panel
Post by panel »
I like this...........
westypoo
Post by westypoo »
^^ holy mess!!! lol! ^^ i like the hidden crankfire trigger idea! ill be doing the same!
seb
Post by seb »
westypoo wrote:^^ holy mess!!! lol! ^^ i like the hidden crankfire trigger idea! ill be doing the same!
+1 its all about making the engine bay as simple as possible...Plus you know your be pulling the motor out regularly so id prefer not to be entangled by a rats nest
panel
Post by panel »
I just like the wheel part I meant :wink:
