I got my intake tacked together, and then finished welding and painting it this weekend. These are just a few pics of the tack job. 1.75" piping mated to a custom .25" flange for the Hyundai throttle body.
I got a bunch of silicone joints and bends from SiliconeIntakes.com, and got those all mocked up as well. This will not be the final fitment location for everything, as I'm trying to get it all under the decklid while closed. I did a few more measurements, and with another 45* bend at the bottom, I should be able to swing the 180* stainless piece a bit farther towards the fan shroud, which will allow the deck lid to close. Just waiting for the next shipment of parts to come in to verify that.
Next was the full flow and the oil feed lines. After a bit more research, I went into the hydraulic store knowing what I was looking for. I got the 3/8" pipethread adapter to JIC/AN -8, and then a few 90* push loc fittings to get to the case. The case was easier, as they just had a 3/8" pipe thread to push loc fittings.
Lastly was the oil feed to the turbo. I went with a 1/8" pipe thread from my 1/8" npt brass tee from the oil pressure port, to a 1/8" to -4AN adapter, to my 12mm banjo fitting on the turbo. So with that said, I have a 1/4" feed line to my turbo.
