Page 8 of 23
Posted: Thu Nov 18, 2004 11:01 am
by James Buchan
www.airspeedparts.com has a few of my welded fans on the shelf if you need a replacement.
Posted: Thu Nov 18, 2004 12:01 pm
by mharney
Thanks James. I have a replacement coming for it. If it's crooked too (I doubt it will be), I will hit them up for one.
--Mark
Posted: Fri Nov 19, 2004 5:59 am
by Bugzlife
Don Jiskra wrote:Fred Sanford Engine Stand
Why not?! that stand has got more reinforcement than the Brooklyn bridge!
Posted: Fri Nov 19, 2004 10:17 am
by mharney
LOL. I'd HATE to do the FBD on that stand.
Well, here is where I am at today. I am going to go ahead and run it in with the old fan, and then swap out for the new one when I get ready to install it.
Just got some details to take care of now, plumbing, linkage, etc..
Anyone as excited as me? How could you be?
Posted: Fri Nov 19, 2004 11:04 am
by James Buchan
I've never had luck with the oil fittings you are using for your full flow, might want to try this:
http://www.thesamba.com/vw/gallery/pix/172800.jpg
Posted: Fri Nov 19, 2004 11:33 am
by mharney
These are pretty much guaranteed not to leak with the hose that I have for them. If they do, I'll switch over before I put the engine in.
On another note, I just ordered my cut to length aluminum pushrods about two or three days ago, and they already showed up. John C is the greatest.
Posted: Fri Nov 19, 2004 1:58 pm
by surfbug
James Buchan wrote:I've never had luck with the oil fittings you are using for your full flow, might want to try this:
No worrys, I'm using that exact setup on my 1914, no leaks
matt
Posted: Fri Nov 19, 2004 10:37 pm
by MNotary
Is that "push-lok" hose? Nothing wrong with that as long as you use oil compatible. Plus no hose clamps needed.
[quote="mharney"]These are pretty much guaranteed not to leak with the hose that I have for them. If they do, I'll switch over before I put the engine in.
Posted: Fri Nov 19, 2004 11:08 pm
by mharney
It's the stuff ACN sells. The blurb says the same thing, basically.
Posted: Sat Nov 20, 2004 1:20 am
by EASY RIDER
Posted: Sun Nov 21, 2004 9:18 am
by mharney
So.. question:
Would NOT having a bushing in the bellhousing cause a starter to stick on and continue to run, and not want to disengage until I cut the main power?
Posted: Sun Nov 21, 2004 9:47 am
by Island bugs
mark seems reasonable to me if you are using a bushing type starter it could "@@@@" and stick. Wayne
Posted: Sun Nov 21, 2004 10:43 am
by mharney
It's on my engine stand.. It's a T2 bellhousing that should have a bushing. I just didn't have one and was lazy, so I tried to crank my engine over with it to make sure it was gonna work, and it stuck. It may be the starter too I guess, if it is sticky itself. I have another starter in my car that is basically new that I can try, but I will get a bushing first and see if that takes care of it.
Only a few details away now. Flywheel on, all oil gallery plugs and slugs in, just need to finish a little plumbing and get it primed, install the electric fuel pump and tank, run gas lines, install linkage, set up crankcase ventilation, install the ignition, install pushrods and rockers, and off we go.
Posted: Sun Nov 21, 2004 11:18 am
by sparkmaster1
Good luck, Tim
Posted: Sun Nov 21, 2004 12:51 pm
by 64 variant
Quit talking and start chalking!, get that bad boy up and running already!!!!!!
