What did you do to your turbo today?
- brookester
Re: What did you do to your turbo today?
Everything on top will be gloss black.
- MarioVelotta
I tried to heat it with my propane torch. I got it to move maybe .0625". Then it seems like the crank soaked up the heat.turbobaja wrote:Heat up that cam gear and it should come off with a good puller. Were the rockers new or reused? My intake valves still don't show any sign of rotating fwiw.
These are the same rockers I have always ran. I don't need the .625" lift of the new cam though so I'm going to get a 1.3:1 set of rockers form Shag.
[email protected]
[email protected]
- Chip Birks
You did remove the snap ring that sits above the brass gear, right?MarioVelotta wrote:I tried to heat it with my propane torch. I got it to move maybe .0625". Then it seems like the crank soaked up the heat.turbobaja wrote:Heat up that cam gear and it should come off with a good puller. Were the rockers new or reused? My intake valves still don't show any sign of rotating fwiw.
- turbobaja
Brookester I tried to get my powdercoater to do my boost hats like that with the 2-tone ribs...he couldn't figure it out. Progress is looking good!
Wow, Mario. I wonder if the .625" lift is what took out your rocker tips? Still, I would have thought the filter would catch the debris before it gets sent to the bearings. How's the oil pump looking?? Make sure the threads are nice and lubed up on the puller and give it hell. Tapping on the puller with tension on the gear might help, just don't pound on it too hard, cranks can bend.
Karl
DON'T QUIT
DON'T QUIT
- brookester
I had some black paint laying around so I used that.
- MarioVelotta
Brass ring is off along with the spacer. I'll try the lube and tap method
[email protected]
[email protected]
Steve Arndt
- MarioVelotta
They are CB, just double checked.
[email protected]
[email protected]
Steve Arndt
I had to hone the inside of my CB gear to fit the CB 82 crank. It was way too tight of a press fit before.
Steve
My Baja Build
My Baja Build
- MarioVelotta
Well that seems to be the winning combo...
[email protected]
[email protected]
miniman82
Same thing here, my CB gears were tight like a tiger. Pat had told me there was a run of them that weren't finished correctly, so I just lightly sanded the crank one before install.
- MarioVelotta
Oh perfect. I guess this is why I should have assembles this myself in the first place. Thanks guys!
[email protected]
[email protected]
Steve Arndt
You need a oxy acetil torch to put the heat in the gear quickly to not heat soak the crank. Get it a dull red in ~30 seconds of good heat bathing the whole thing, then slam the puller on it and give it hell. The worst you will do is break a puller if you use a small 3/8 impact gun on it. It should snatch that gear off. It went on after all
You could throw the crank in the freezer first to get a little extra working time.
Steve
My Baja Build
My Baja Build
- turbobaja
You might contact CB Perf and see if they will sell you just the crank gear. Cut/grind the gear off if you have to...carefully. Depending on the cost it might beat hurting the crank and/or your puller in the process. Wish you were a little closer Mario, for more than a couple reasons
Karl
DON'T QUIT
DON'T QUIT
- MarioVelotta
I don't have an oxy torch unfortunately. Just a mapp gas torch. I'll go try again.
I feel ya brother! I'm going to have new kit version soon though. It may be right up your alley for the wifes beetleturbobaja wrote:You might contact CB Perf and see if they will sell you just the crank gear. Cut/grind the gear off if you have to...carefully. Depending on the cost it might beat hurting the crank and/or your puller in the process. Wish you were a little closer Mario, for more than a couple reasons.
[email protected]
[email protected]
