What did you do to your turbo today?
Re: What did you do to your turbo today?
Post by Chip Birks »
Are they the same as mine? Have you received them yet?
seabeebuggy
Post by seabeebuggy »
Well after 10 years? i pulled my carbs off for a rebuild. I just could not get the car to run with out spraying fuel. Ordered rebuild kits from e bay. I wanted to get them from CB performance but they wanted 18$ to ship. No thanks.
58Dub
Post by 58Dub »
did some engine mock up yesterday.... slowly getting there.
madmike
Post by madmike »
Drove my 2276 yesterday, while my son watched&listened he's more up on turbocharging then I :oops:
once in a while I heard a bang :shock: just when I shift to 4th,, it's was the wastegate :lol: slicks on a sandy/dirt road is fun :shock: :lol:
still have stock trans :oops: stage I and a sprung center 4 puck :wink:
this sunday drags at Boyne City will be the 2nd time I've run it on pavement 18lbs in the slicks will help save the trans i hope
I'll just have some V8's 8) yes, my lil' crew chief will be helping, not quite 2yrs old and his 2nd drag event :D ,, I'll post the results next Monday :wink: Thanks for all the help guys!!!!
Madmike
madmike
Post by madmike »
Had a huge puddle under the 4qt sump :oops:
Must of smacked a 'sex Stone' on my road again :? :cry: :|
yepper, even broke the main stud holding the pick-up tube in place :cry: :cry: :cry: :cry: :cry:
always right before the big race up here,hope i can fix before Sunday :roll:
can I get away with just a 1 1/2 sump?
Fiatdude
Post by Fiatdude »
Drag racing will allow you to get away with a smaller sump -- the bigger sump is needed for cruising for temp control and road racing to keep some oil around the pickup
madmike
Post by madmike »
I had to change the 4qt for a 1/12 yesterday :oops: PITA in the car but it's done :|
good to know Fiatdude 8) hate to spin a 'Carrillo' rod bearing :shock: :cry:
madmike
Post by madmike »
Tip:app. for Deep sump,, for a pick-up tube extension I use a old aluminum empi adjustable/spring loaded tube(junk anyhow) cut to fit
they are perfect for this 8) 8) 8) 8) seal/attach with JB weld,no more running to the hardware for conduit that don't fit right :lol:
hope this help someone? ,I've spent hours looking for the right size tubing before :roll:
Madmike
58Dub
Post by 58Dub »
doing a little mock up with the CB turbo header
sideshow
Post by sideshow »
Gasp, somebody stole ye-ar oil cooler hole! 8)
58Dub
Post by 58Dub »
sideshow wrote:Gasp, somebody stole ye-ar oil cooler hole! 8)
lol... yes, Michigan is a high theft state!
dave t
Post by dave t »
WBX case?
58Dub
Post by 58Dub »
yes
madmike
Post by madmike »
I drove the piss out of it yesterday .about 60+ miles :D
with the 'cruise' motor 1915cc 45 dcoe draw threw,, about 14mpg ,, with playing :wink:
madmike
Post by madmike »
Time to clean out the Garage.
My old Turbo set up is for sale see pic above^
T04 carbon sealed Roto-Master ,turbine 68a/r compressor 60a/r
header & wastegate all for $850. adds on theslamba :wink:
