Kbwakesk8's cars ,i need help!
- Leatherneck
- Leatherneck
- KBWAKESK8
All the parts are brand new except the caps but they where cleaned and sand blasted. I even took the seal out to see if it will tighten up.Leatherneck wrote:IF it is not sucking it up it must have a piece of metal or something blocking the way, all areas are flush and smooth?
I think i will take the bearing out and see if i can get it to tighten up . just trying to eliminate posabilitys.
- KBWAKESK8
I have no clue what it was but i took it all apart checked every thing put the bolts in the holes to see if they where bottoming out. nope I put it all back together and it worked go figureChadRat wrote:Sounds like your bolts are too long. When I make trailing arms, I drill out holes behind the bearing carrier just in case. Try some bolts that are 1/8" shorter.
So i got the car rolling again.
Put i have another problem. who ever it was that had the car before me and did the swingaxel to irs conversion welded in the pasanger side mount at the wrong angle . so i have to cut it out and start over. is there anyone local that has a irs jig i can use.
- Crash
You better put those in a jig before you weld that much to them or they will warp like crazy.
-Mark
-Mark
________________________________
Mark "Crash" Johnson
Blind Chicken Racing
www.blindchickenracing.com
- KBWAKESK8
Ya i know haven't figured that part out yetCrash wrote:You better put those in a jig before you weld that much to them or they will warp like crazy.
-Mark
still working on fixing the pivit brackets they where originaly welded in wrong so i had to pick up the jig and brakets from mckenzies .
the plasma cuter made it alot easyier. but i still have a good amount of grinding.
DesertGuy
Don't know about the one over at TOS, but for an inexpensive cell, look at JAZ Products. If you pay for it at Pomona Swap Meet and have it shipped you can usually get it for a little less.
RCI makes some shortys also...
http://store.summitracing.com/partdetai ... toview=sku
- rickosuave1987
The one on the samba is a little different, but Latest Rage makes one very similar. Replaces the back seat. I can get them for about $140
But, there is no way to get foam into the tank. It has a very small filler hole.
Baja
HookIt
SuaveRacing FaceBook
HookIt
