What did you do to your turbo today?
- seabeebuggy
Some time soon I will start retuning my engine. It runs ok , boost is slow to build and very rich. When my alki comes on it bogs the engine. I now have a list or things to do. I also get my new home today. Or at least it closes and I still need to wait up to 2 weeks for the sellers to move out.
www.BigMikesGuns.com oe https://www.BMGAA.com
Thomas Jefferson said It may be necessary for a country to have a revolution every 200 years to right the wrongs of a Government.
Got Lead?
Got Lead?
Odyknuck
Well I hope that the Turbo is the only thing gone and the smoke out the exhaust was oil burning from the Turbo and not the engine. It was smoking quite a bid when you let off the throttle. When I took the turbo apart there was fresh oil under the impeller. There is a little smoke coming from the crankcase breathers. Glad to see the Home closing.
- MinamiKotaro
Some pics of my new setup:
The whole engine. Went back to the 2x48 CB TB.
Ford plug wires with retaining clips.
Vacuum manifold.
New EDIS wheel mounting. Looks better, too.
Better mount for the Tru-Boost. It was just zip-tied on before.
CB dune-buggy throttle cable. Much better then the bellcrank we had. MUCH. Also, "LETHAL VOLTAGE".
George II
Vacuum manifold.
George II
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
miniman82
- MarioVelotta
Yeah, what's up with the intake stuff? I thought you went to the plenum with a 50mm tb?
Did you just sandwich all the part together for your trigger wheel?
Cool you got your tru boost working.
[email protected]
[email protected]
- Wally
- MinamiKotaro
That's how it was before. It's unreal how much better everything works with the manifold. The MAP signal is so steady it brings a tear to my eye.miniman82 wrote:I opted for a single line Tee'd off about 6 times to the various things-boost controller, MS, BOV....
At first, but it wouldn't get tight enough. It's JB Welded, now. Going to put at least one setscrew in it as well.MarioVelotta wrote:Did you just sandwich all the part together for your trigger wheel?
I think it works. Increasing the PWM from 10 to 20 took me from ~7 to ~8 lbs boost, increasing PWM from 20 to 30 only got me to ~8.5 lbs boost. Perhaps the wastegate spring is just that wimpy? I know the spring crack setting works, at least, because the turbo spools way, way faster now that I've turned it up.MarioVelotta wrote:Cool you got your tru boost working.
Now that I've got the better throttle cable instead of the homemade bellcrank, the CB TB works quite well. Generally knowing how to tune MS better helps, too.Hey, I thought you said the dual TB intake wasn't working very well for you?
According to my G-tech (which we all know is sooo accurate
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
Master slacker
miniman82
- MinamiKotaro
- MinamiKotaro
