Wait a minute...Did you break a Hi Power Ring and Pinion???
Got my ej20t
- dlamyle
Re: Got my ej20t
1968 Karmann Ghia, JDM EJ205, Subarugears, OBX LSD, Blouch 16g XTR, Killer B Headers, DW 750cc, Meth Inj, Cobb AP w/Mach V 22psi Dyno tune (332whp)
Videos
Build Thread
Videos
Build Thread
- bad62bug
Re: Got my ej20t
- dlamyle
Re: Got my ej20t
Well that's a relief, still sucks but at least you're not sitting on a time bomb anymore. I'll admit I'm a bit jealous of your "new parts yesterday for free no ? asked" from Todd. I must have been one of the first street cars to pop one of these because I did not get the same treatment at all...
Videos
Build Thread
Videos
Build Thread
- bad62bug
Re: Got my ej20t
Most likely didn't realize the extent of the problem. Sucks you didn't get the same deal. if i didn't i most likely would have had a bus trans built.
It sucks how much gear sets cost for these trans, now I'm worried i'll tear the teeth of the gears.
On a side note do you have any timing values (Like at full boost and under lite load cruising.
- dlamyle
Re: Got my ej20t
Yeah I have very little faith in the strength of this metal for our applications.
I get all my tuning done for me at a shop. I'd log some data but right now my car is stripped down for paint.
Videos
Build Thread
Videos
Build Thread
- bad62bug
Re: Got my ej20t
OK Thanks, last year I was running a ton of timing this year I'm starting on the conservative side.
What size rear tires are you running, I'm on 235/50/17 continental extre contact.
- dlamyle
Re: Got my ej20t
Nitto NT05 235/40/17. And I'm definitely at the limit for a Ghia with the rear fenders mostly intact. I've been doing some widening on the fronts while the car is in bare metal. I'll update my build thread with that soon.
Videos
Build Thread
Videos
Build Thread
Shopoz
Re: Got my ej20t
How're the continental tires? Would like to know your feedback on that. I've seen some reviews comparing it to michelin pilot.
turboedbug
- surfbeetle
Re: Got my ej20t
HA HA, it took me over 15 years to get mine installed and running. Life has the ability to easily get in the way...turboedbug wrote: ↑Fri Mar 12, 2021 5:24 am I swear this is the longest project I have ever worked on hahahahaha
turboedbug
Re: Got my ej20t
lol ya we share a pretty comparable time line hahahaha. I did have it running in the past. currently going through and modifying all the short cuts and things i dont like as of now.
Here's a little update on my never ending project hahahaha
https://youtu.be/6JaGEb_mKys
Turbo!
turboedbug
- panel
Re: Got my ej20t
What intake manifold is that ?
turboedbug
Re: Got my ej20t
It's an obx ITB setup.
Its a pretty crappy setup out of the box fyi.
I had to have it milled flat and do alot of work to make it fit right.
Whats sad is I just had a change of heart on it. From what I have been reading is itb's are known for poor vacuum signal to a map sensor.
So I will be using a short runner intake to get this up and running. Then after some drive time I might consider trying it out after everything has been confirmed to work as Intended.
Turbo!
turboedbug
Re: Got my ej20t
So here's the current pinion to ring gear mesh i have.
What do you see here?
Turbo!
