CENTERMOUNT FAN SHROUD DUCTING INSERT
Lo cash lester
Re: CENTERMOUNT FAN SHROUD DUCTING INSERT
Post by Lo cash lester »
Piledriver wrote:With the right lasercut bits and a few tabs for alignment the steel setup could become a kit anyone could weld up...
We have a plasma cnc table. That’s how I cut everything out. Was thinking about selling a knock down kit. See how everything goes, time will tell.
i'm in for two.
You could probably do knock down t1 and t4 gen stands for it as well, as they also are apparently unobtanium these days as well.
I'm gonna hafta build one of those plasma tables RSN...
Godzilla (TD Pak 100XL) doesnt get used enough.
Do need to carve out some Lexus ls430 caliper mounts for my vanagon this weekend.
Lo cash lester
Fully welded and mocked on car. Have a few changes to make but nothing crazy. That’s all for now.
FJCamper
Post by FJCamper »
You do have the ducting vanes in place, right?
Great photo.
H2OSB
Post by H2OSB »
Lo cash lester wrote: Tue Mar 23, 2021 5:34 pm Image
Those sure do look good. I always think of the Porsche 356 with dual carbs every time I see one mounted in an engine bay.
H2OSB
Lo cash lester
FJCamper wrote:You do have the ducting vanes in place, right?
Great photo.
This is what I have. We’ll see what happens.
FJCamper
Post by FJCamper »
Good luck testing. I'm impressed.
phulc
Post by phulc »
Crazy sh..
How did it work out?
Related-ish:
Saw someone selling lightweight molded plastic fans for T1s at some other site. Look nice, straight radial fans.
Considering getting one to finish my Corvair-ish setup as they are non directional.
Cant find link at moment... ah, it was seen at that face-thing site where good threads all go to die...
https://www.andrigsaircooledtechnology. ... ooling-fan
terryly
Post by terryly »
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
dragvw2180
Post by dragvw2180 »
My friend contacted them about the plastic fan assy , the company is developing a new one with metal hub to make it stronger .
dragvw2180 wrote: Thu Oct 07, 2021 9:56 am My friend contacted them about the plastic fan assy , the company is developing a new one with metal hub to make it stronger .
Good idea.
They should make one for Corvairs, could be same one with the vw one cut down a little and different hubs.
Any Corvair with a mag fan needs a new one yesterday, the fins all crack at the roots eventually.
Post by Chip Birks »
Lo cash lester wrote: Thu Mar 25, 2021 4:51 pm
Great photo.
Any update on this?
`Ya know, with those straight bladed lightweight fans being non-directional, you could actually use a pair in a look and work-alike og style twincam fan housing.
(if you had unlimited time and money, of course)
Lo Cash John
Post by Lo Cash John »
Chip Birks wrote: Sun Oct 10, 2021 11:26 pm
Great photo.
Any update on this?
Car is still under construction
