Type 4 DTM V2.0 is ready to sell! Pics within!
buggpower
Post by buggpower »
thanks, would it be worth buying to use on a 1600cc or 1641cc or would i be better off with the stock one? my motor has the chrome aftermarket shroud on it, an i dont like it.
Class 11 streeter
Post by Class 11 streeter »
buggpower wrote:thanks, would it be worth buying to use on a 1600cc or 1641cc or would i be better off with the stock one? my motor has the chrome aftermarket shroud on it, an i dont like it.
You will go bigger on motor someday, the DTM will easily handle that fine.
Most chrome aftermarket shrouds are not built to the quality standard the OEM shroud is but it's getting harder to find a complete unmoltested VW shroud with all the parts, the DTM will have everything you need in one box.
buggpower
Post by buggpower »
bigger...me? nah, going turbo...im cheating :lol: ok..well later on eventually.
seahag
type4 dtm
Post by seahag »
Jake, What's up with the "velocity stack" looking bell on the rear of the fan? Does it really improve the air flow or is it basically a cosmetic item? I would believe it would help to straighten/increase airflow. Does it? Seahag
werka
Post by werka »
If it was straight, you would have turbulent flow interfering with the "clean" flow. With the "velocity stack" if there is turbulent flow it should be around the stack edge, so you should have more "clean" air flow as a result.
Post by MASSIVE TYPE IV »
The stack is mainly used to quieten the fan sound. In the Spyder the engine is 8" behind your head so it can get annoying..
It has shown some cooling benefits.
seahag
Post by seahag »
How much fan noise reduction would you say the stack comtributes? I too have an open air vehicle and the fan noise reduction would be great. Seahag
Locked
