Making progress...
- Leatherneck
- Skidmark
I started my wiring install yesterday. Here are some initial shots.
You can see the brake line and clutch line routing in the last picture...
I also started installing the rear shocks...
I figure the wiring should end up being around 40 hours to complete, not counting the multiple trips to the store for more connectors, wire, shrink tubing etc... I want to take my time with the wiring so it comes out very clean.
- Leatherneck
anzan wrote:The car is looking great! What will you do for e brake? Also, what (if anything) will you do for rear fenders. I need to come up with some rear fenders myself.
Will one of you guys please help this man out?anzan wrote:Man, your car is such an inspiration to me! What are you going to do about rear fenders? Looking forward to hearing about the shakedown cruise...
anzan, take a look at David58bug's fenders.
- david58
Looking great there Skidmark. My 65 shell's wiring harness is in great shape I plan to update the fuse panel to new style fuses and am looking for a fuse box the has the screws in it to connect the wires. This pic below is correct except for the type of fuse I want to use.
- david58
Leatherneck wrote: Will one of you guys please help this man out?
Go to:
http://www.shoptalkforums.com/viewtopic ... sc&start=0
for more pics.
- david58
That is not a fender that is one of those fangdangled rear bra'sanzan wrote:Thanks for the pic David, That is some fender! But, I think those 'high riders' are more of what I had in mind.
- Skidmark
They mount above the stock location. You have to drill your own holes and provide the mounting hardware. I am going to use a threaded insert like this...
http://www.avkfasteners.com/Products/AKProductPage.htm
I already have the installation tool at my work, which makes it an easy decision. If you don't have the tool, you will need to get one to use these.
- Leatherneck
- Skidmark
You don't have to use air powered for these, they make a manual tool - like a pop rivet gun. It collapses the main body, pulling the threaded portion toward the surface of installation. It "crimps" itself onto the sheet you are installing it into.
http://www.avkfasteners.com/tools/handtools.htm
David, these don't screw into the work piece... you drill a hole, insert the fastener, and then crimp the fastener to the work piece with the tool. The knurled body sandwiches the workpiece, so it will resist spinning when tightening a screw into it after installation.
- rickosuave1987
