Transmission Pics VW/Non-VW used in bugs, vans, etc.
- Wally
- ttriebler
Re: Transmission Pics VW/Non-VW used in bugs, vans, etc.
Subaru 5MT gearbox fitted into type 1 VW pan. Subaru gearbox fitted with reversed ring and pinion to allow fitting in rear engined cars.
More info at http://www.subarugears.com
Standard OEM gears vs reversed gears
Relief on opposite side housing to clear ring gear bolts
Box in type 1 pan with EJ20 engine block
Shifter location, just to the right of original VW shifter
Upside down, showing clearances and engine height increase vs VW box
Mount mock up. Decent triangulated engine mount needs to be made
Close-up of gearbox mount, sandwiched between 2 x poly suspension mounts
Flatfourfool
any one have info of 091 into 70 ghia? can it be done without cuting or welding?
matberry
Re:
4bkila wrote:anyone fitted or seen a renault zf four speed in a manx/baja i'm wanting to do the swap but would like more informed opinions about what's required etc[/img]
Better late than never.
The tranny I'm using is a ZF 4 DS-18 (Renault truck 4 speed that aparently started life in the BMW M1). Gear ratios are a bit short even with 31" rubber. It fits without cutting torsions, and a kombi bell housing adapted relatively easily by making an adapter plate.
- boxertje
jabcok20
boxertje hej do you have more photo with renault boxes in vw beetle? what about rear suspension?
Thanks Henry. I must have been going too fast and missed it.
