VdubsNWPA wrote:First of all I'd just like to say that this Forced Induction forum is awesome! After reading all of the info you guys have provided I feel like i'm ready to dive into a turbo setup. I'm going to turbo my rail first, and if it works out well, i'll do it on my 72 bug.
MO, I love your setup! I'm planning on doing almost the exact same thing.
questions: I'm looking for a 2 barrell holley to use. Are there any that I should avoid? I'd like to use the same thing you did so I can set it up the same to give me a head start on tuning.
Also, I have a lead on an old T25 from a dsm. It supposedly has play in the shaft. i've seen rebuild kits for turbos and they're cheap... is it hard to do a rebuild?
and info is appreciated!
I haven't tried a Holley 2 bbl..
I've been so pleased with the performance and driveability of my 390 4 bbl. I'll never even entertain the thought of a 2 bbl. now!
Watch Ebay for used 390's.
They're inexcusably expensive brand new.
As for rebuilding a turbo, NOTHING TO IT.
Just take your time, watch how it comes apart and keep it
clean as you reassemble!
As for your potential T25:
Make sure there is not so much shaft play that one of the wheels has contacted either the turbine or compressor housing or maybe the shaft has damage from a failed bearing(s).
If so, steer clear of it!
My turbo didn't "need" a rebuild but as I was installing the necessary carbon seal for draw through operation I went ahead and replaced the bearings, clips, etc..
I got my kit from gpopshop.com.
Not to say they're the cheapest but MAN are they helpful and they know they're turbos!
Remember....if you go draw through, you'll need the kit with the carbon seal to keep the oil from being sucked into the compressor housing!
My DSM T25 came with a bend at the compressor outlet.
I cut it off and blended the remainder straight.
NO problem! It's aluminum and there's plenty to work with there.
ANY questions? Don't hesitate to PM or e-mail me.
