Page 2 of 6
Posted: Thu Nov 15, 2007 6:04 pm
by baja kid
Mr Bs Bug N Buggy wrote:
baja kid wrote:
and i also have a question about valve cover gaskets. the last time i adjusted my valves i didn't replace my gaskets and after i got home from my trip from the desert last weekend i noticed that i was leaking a fair amount of oil from the top and bottom from my vale covers and i was wondering if i am so posed to replace them every time i adjust the valves.i assume that if i do replace it it will stop the leaking right. thxs
Yes, if you are using cork gaskets "I" like to change them each valve adjustment, they are cheap.
I have switched over to a rubber type gasket and I use them several times, well infact, I have not changed them since switching on the buggy.... :wink:
I believe you are correct, if you did chase the leaking to the valve covers, then yes change the gaskets and it should stop, a little unusual for them to leak at the TOP.
im not sure if they where leaking from the top but i saw just oil streaks on the valve covers and assumed that the oil came from the top not sure any more i degreased my motor and washed that car after the trip. the gaskets i have been using are the cork ones i might try the rubber ones now. thanks for the tip
Posted: Thu Nov 15, 2007 6:09 pm
by Mr Bs Bug N Buggy
Just keep an eye on it now that it is clean, you will find it and be good to go...... :wink:
Posted: Tue Nov 20, 2007 10:55 am
by 72bajaben
baja kid wrote:its a 22 gallon tank and its flush with the luggage area where my speakers are so it works great for a place to store stuff haha. my car dosent have a trunk and there is not very much room in the interior so every bit counts. do u have pics of your tank in your profile i would like to check it out. the battery is mounted under the passenger seat.thanks for the complement on the car too. the po did most of the grunt work transforming it into a baja bug but my dad and i have also done a lot of the work really making it mine.
All i have is a 16 gallon poly tank mounted in the luggage area. But i will get some pics of it if you want.
Posted: Tue Nov 20, 2007 3:47 pm
by baja kid
sure the pics would be great anyways i might be going out to ??painted Gorge?? this week end with a couple of friends and i have never been there. does anybody know what its like out there?? ill be driving the baja out there and back so it should be an adventure 8) anyone ever been there?? thxs
Posted: Tue Nov 20, 2007 8:20 pm
by sxuxrxf
My tank is almost identical. The dimensions are:
37" long x 21.5" (top) 15.5" (bottom) x 6.5" tall. I don't know the capacity. (it will be a while before I do :( ) I'm sure one of you math wizards can figure it out anyway. It has one baffle in the center to keep the fuel from sloshing around.
It fits perfect, leaving a flat surface on top all the way back. I'll put tools/tow straps and stuff under the tank and the battery will go up front.
Posted: Tue Nov 20, 2007 8:36 pm
by baja kid
man thats gonna look good i wish i had a baffle in my tank sweet deal
Posted: Tue Nov 20, 2007 8:56 pm
by sxuxrxf
You might, our tanks look like the same manufacturer.
Posted: Wed Nov 21, 2007 10:24 am
by baja kid
sxuxrxf wrote:You might, our tanks look like the same manufacturer.
i dont think so my fuel sloshes around a ton specifically when there is low fuel and i step on the breaks hard i can hear it going back and forth. i dont know i might but i drought it.
again does any body know anything about painted gorge or it might be painted rock i dont know im going this week end with some friends and have never been there it is so posed to be out my ocotillo ??
Posted: Wed Nov 21, 2007 12:18 pm
by Turbo_Manx_Maniac
I was out a painted Gorge last weekend, it's more of a spot for dirt bikes IMHO. After you climb around for 1/2 hour I got bored, of course I like the faster wash runs myself.
If you want some good trails, go to Aqua Caliente, or ride the pole line road and go to superstition. Ocotillo is a great place, it offers all kinds of riding, especially if you are street legal.
If you want to test your car, run around one of the MDR courses. It will test your suspension and your driving skill. Try and run through 2 miles of 3 foot deep close whoops, and get out of first gear.... :twisted: Kind of gives you a different perspective on the trucks going through them at over 100 MPH, expecially when you can't get over 10 MPH without killing yourself.
Have fun!
On the valve cover leaks, get bolt on's.
Posted: Wed Nov 21, 2007 1:18 pm
by 72bajaben
who made your tank. I was thinking about making one myself, but why go through the trouble is someone already makes them.
Posted: Wed Nov 21, 2007 1:34 pm
by 72bajaben
Here are a few pics of my fuel cell. They were from when i installed it. Im not a big fan of where its mounted, that is why i like yours so much, i wanna redo mine very simular to yours.
Posted: Wed Nov 21, 2007 2:03 pm
by rickosuave1987
sxuxrxf wrote: I'm sure one of you math wizards can figure it out anyway. It has one baffle in the center to keep the fuel from sloshing around.
From my math it is about 19 gallons. But i have been wrong before. :lol:
Does the baffle only go in one direction?
I personally like the foam-ed tanks like the one I have. i have no sloshing issues at all. 8)
Posted: Wed Nov 21, 2007 6:46 pm
by baja kid
72bajaben
it does not look bad at all i liked how you ran your filler up there it looks cool but is it not a pain to put gas in it?? i liked the shoptalkfourms sticker too 8)
Posted: Wed Nov 21, 2007 6:55 pm
by Projectile Motion
I like the low down style of those tanks. I am going to notch out a bit of the rear "tray" to get my tank to sit a little lower and it will still be higher than yours.
By the way, you can buy foam blocks for your tank to reduce the sloshing. I think summit sells them for a good price.
Posted: Wed Nov 21, 2007 10:07 pm
by baja kid
how would i add a foam block to my tank and i haven't had any problems with the sloshing just sounds funny when my tank is low. so whats the benefit of foam blocks??
