She's Running!
richie,uk
Post by richie,uk »
Matt Keene wrote:The inlet manifold runner has been extended since these shots. All work in progress :D
All talk and not enough progress :P :)
cheers richie,uk
www.rjvolksperformance.com
We make VWs go fast!!!
Thing4vw
Post by Thing4vw »
You sick bastard :twisted:
panel
Post by panel »
Was there ever any video of this thing :?:
Humpty
Post by Humpty »
Yeah Matt... Where are you mate.... Haven't heard from you ages?
SiQDiZ
Site Admin
Post by SiQDiZ »
The new trend, only use turbos bigger than your head applies here too :o
Matt Keene
Post by Matt Keene »
Here's some more progress shots. Been a little too busy recently to get on the forums, as I have moved workshops yet again!
I then started work on beefing up the bodyshell in areas that are prone to cracking. A little bit of panel beating and swaging goes a long way for rigidity!
I decided to fabricate my own Crotch Coolers a la Split Bug, but with a twist. The twist is they open backwards to let air out of the front inner wings...
A big thanks to Stian Abel Larsen for sending me a pattern of an original crotch cooler! Cheers bud! Anyway, I made the cooler flaps out of ali sheet with brass meshing...
With the body mods done, it was time for an entire sandblast of the whole bodyshell inside and out. I still have sand come out of my ears every now and then...
Ben then blasted on some zinc primer
Matt Bown came and helped smooth out the bodyshell and laid on some two-pack primer mixed with two-pack green base coat. I really dig the finish. It looks uncannily similar to Stian's car...
Time to start work on the dash layout. It had to be basic, but functional. The Autometer and HKS programmable boost gauge take pride of place...
Wayne and I worked on the ali paneling together - it's pretty much done now
I wanted a heavy battery with loads of power right over the nose of the car to help keep it straight. I made the mounts from Zintec
Matt Keene
A little more...
I modified a Jazz seat to fit and had it recovered in leather by Matt Leach. Looks wicked in my opinion!
The engine looks a bit more tidy now...
I sourced an Oval bonnet from Dave Dinning (cheers Dave!) and chopped and modded it so that is quick release. I bought a Split Bug bonnet handle and drilled the crap out of it!
Here's a side on shot of it recently...
Humpty
Post by Humpty »
That is looking so dang tough Matt... You must be stoked!
Not long now and she'll be on the track....
Can't wait!
panel
Post by panel »
Lots of drilling through-out I see :shock:
MarioVelotta
Post by MarioVelotta »
Very impressive, It Looks sick!
[email protected]
55superbeetle
Post by 55superbeetle »
LOVE when poeple think outside the box. Coolest project i've seen in a while!!!
panel
Post by panel »
55superbeetle wrote:LOVE when poeple think outside the box. Coolest project i've seen in a while!!!
You shoulda gone this route :wink:
Wally
Post by Wally »
Very nice metal (and alu) work! total respect for your skills!
But where did you put the radiator?
RonW
Post by RonW »
Wally wrote:Very nice metal (and alu) work! total respect for your skills!
isnt that is in the upper L hand corner?
912R + STi 2.0 Turbo JDM v8
Marty
Post by Marty »
SWEET!
