FI Build-up - German Plenum/TB & MS-1
j-bro
Re: FI Build-up - German Plenum/TB & MS-1
Post by j-bro »
I never thought I'd say this about an upright engine rocking the stock plenum, but that looks pretty fuggin awesome.
Vee Dub Nut
Post by Vee Dub Nut »
j-bro wrote:I never thought I'd say this about an upright engine rocking the stock plenum, but that looks pretty fuggin awesome.
Thanks... I'm very happy with how its turning out so far.
Hotrodvw
Post by Hotrodvw »
Yeah, nice set up! My turbo set up would prob fit w/o too much modification. :D
Vee Dub Nut
Hotrodvw wrote:Yeah, nice set up! My turbo set up would prob fit w/o too much modification. :D
yup I think so... someday :mrgreen:
WickedWagens
Post by WickedWagens »
You could do a cb hideaway header and run your ducting up to the throttle body real easy.
Vee Dub Nut
WickedWagens wrote:You could do a cb hideaway header and run your ducting up to the throttle body real easy.
Yea, that is the other option I'm toying with down the road. Need to just getting running as is first.
Miggy
Post by Miggy »
Am I right in thinking that the "german" tb/plenum/alt stand is the one from the super beetle l-jet setup ?
Vee Dub Nut
Miggy wrote:Am I right in thinking that the "german" tb/plenum/alt stand is the one from the super beetle l-jet setup ?
Its from the late model Beetles (super or standard) with factory fuel injection. (Not sure about the l-jet part, I'm not familiar with all of the different injection system names)
Miggy
Post by Miggy »
Ah right, I can honestly say i've never seen any vw retailer over here selling them!
Vee Dub Nut
Did a little more fitting on the engine. Got the intake runners installed, gasket cut for the oil filler and it installed, throttle position sensor installed, air filter, and some other small bits.
Honestly, I don't really care for the air filter. It looks a little out of place, and a little ricey. Unfortunately, I haven't found any better options at the moment, so it will have to do.
Intake runners:
tps mounted with Mario's adapter (supplied in the kit):
fuel pressure gauge on the rail. Its just temporarily screwed in until i get some sealant for it.
topish view
Hope to get the new supply line run this weekend, and start with some of the wiring. Getting closer, but still plenty to be done.
miniman82
Post by miniman82 »
Good luck reading that guage when the engine's in the car. :wink:
Thats why I put mine on a AN line coming off the regulator, so I can position it where it's easy to see when setting base fuel pressure.
Vee Dub Nut
miniman82 wrote:Good luck reading that guage when the engine's in the car. :wink:
you may be right about that... I'll find out for sure when I get the engine in the car I guess.
CLKWRK
Post by CLKWRK »
I have the same tps and it mounts the other way, did i mount it wrong?
Vee Dub Nut
CLKWRK wrote:I have the same tps and it mounts the other way, did i mount it wrong?
Your probably right.. I think I may have the adapter backwards. I have an email in with Mario to confirm this though. I was guessing tonight when I was mounting it.
Depending on which face of the adapter you have against the TB, the orientation of the TPS changes.
panel
Post by panel »
Vee Dub Nut.........I love how clean your motor is. Just noticed you had that ugly plug in there.
To keep your really clean theme going............try to get one of these plugs.
