Ok, thanks for the answer.xellex wrote:Ngobet,
Yes, I am using the 944 late spindles, but I won't recommend it, as it limits your choice of struts because of the different bolt pattern, and also because you will have to drill a hole through it for the speedo cable. It's much easier to use the early (pre 86) 944 spindles.
I don't know what you mean by the upper/lower diameter of the tie rod, but I will measure it if you can explain
I have no noticeable camber problems, but these custom struts have the adjustable upper bolt, just like the original Porsche struts, which gives you a bit of adjustability, and also, I have the topline camber adjuster bolts/bushings.
I wanted to use the 944 MC because it was in much better shape than my old one. From what I've read, it's best used in combination with the bigger porsche callipers, and the best MC for the NA 944 callipers would be the original super beetle one.
You can find all the info you need on these forums, and also on the germanlook.net forums which are back online for a while now, but you probably already know that![]()
For the diameter, I was just wondering if you measured the custom tie rod you bought from Kerscher. I'm sure it is directly available from the dealer.
thanks
