Chip's Turbo EFI Build
- Chip Birks
Re: Time to spill a little...
Thanks! This is only one part of the "different" stuff, the rest will come when I am good and ready to share it, hopefully after she fires...
my_medusa
damn...looks like my old supercharger setup that i stoped because of getting addicted in 36hp engines.
if you dont like the long and and curvy way to the TB you can wount the TB behind the shroud.
looks good at all.
if you would welding the intercooler you coul save alot of way by going next to the shrout through the firewall and go out with TB on the backside.
maybe it is possible without welding. TB on the backsinde needs ney runner lengths.
but i think how it is will work very well. you will see.
i also really like the 22 pin! that is easy and brilliant.
my system in now in an other car we welted the intercooler do fit next to a porsche cooling system with the TB 1600i mountet backside...
this is befor welding the intercooler to fit.
you gave the blackline57 guys your car last season right?
honorable
wishes from germany
looks good at all.
honorable
wishes from germany
- ToRy 70
Did you use the proprietary crimp tool, or other means? Sorry for the tedium.Chip Birks wrote:The firewall plug was just like any other weatherpack connector, tedious, but not difficult. It comes with multiple gauge inserts, so that was nice. Mine will be completely populated when I'm done, 22 pins barely covered it. But it worked out well enough.
- MarioVelotta
I use something similar to these. I got them from NAPA and they work good.
[email protected]
[email protected]
- Chip Birks
crimpers are similar to the ones Mario showed. Wish I had the real deal though. DIY sells some nice looking ones.
Small Update:
Got the header hung, Its a very nice part, I am extremely pleased!
It tucks up very high, very stealthy
Small Update:
- Chip Birks
Talk about motivation to get the car together, got home from Sac at 4am and am ready to get my car back on the road. There were some KILLER turbo'd street cars there. Geez, I can't wait to get this thing running!
- Chip Birks
More changes are on the way. Saying good bye to the Mexican stuff, hello to something that will flow some serious air.
oh yeah, the mexican stuff is for sale. Pm if interested.
- WickedWagens
I was wondering what you were doing when I saw your mexi stuff for sale last night.
- Chip Birks
Haha, yeah, now, if only someone would take it off my hands...
- MarioVelotta
Too bad I just picked up 3 more sets
[email protected]
[email protected]
- Chip Birks
Nice timing, lol! Antonio was the exclusive seller of these things and now that mine is for sale it only makes sense that there are 4 sellers all with the same thing, haha! Oh well.MarioVelotta wrote:Too bad I just picked up 3 more sets
- Chip Birks
Re: Time to spill a little...redo redone...
Since my last post, I've done some major parts collecting from all over the country and have finally had some time to actually work on it. Made a little progress in the last couple days. Its been slow going but the vision is finally being seen in real life.Chip Birks wrote:More changes are on the way. Saying good bye to the Mexican stuff, hello to something that will flow some serious air.
I managed to move the Mexican stuff, and a few other things. The top half is just about ready to tig up and then I need to get the pipe from the turbo to the TB finished up. Waiting on my tb flange right now though. Hopefully I can get that done this week. Throttle body will be mounted right before the pipe goes through the shroud into the intercooler.
- Turbo Farviknugn
Where did you score the steel flanges for the intakes from ?? I could use some of them !!!Chip Birks wrote:Chip Birks wrote:![]()
BTW Nice looking set up !!
- WickedWagens
Re: Time to spill a little...Redo REDONE!
Wow! that is quite a change. Are you planning on doing any sort of transition(like a velocity stack) where the individual runners take off from the plenums?
- Chip Birks
I actually had them made by a friend of mine, not sure if I can get more though. The way we did it wasn't the most productive way, but it was what we had. It would be nice to get some water jet cut, mine were done on a cnc mill. Kind of a slow process to cut the steel, but they turned out really nice. Talk about some precision cut pieces, I told the guy to go 2" I.D. for my 2" pipes. Turns out that pipe isn't quite that precise. It about killed me to have to take the die grinder to the inside of the perfect flange to open then up a couple thousandths.Turbo Farviknugn wrote:Where did you score the steel flanges for the intakes from ?? I could use some of them !!!
At this point I was just considering leaving them as they are(obviously ported to full size though), there is just not a whole lot of room inside those 3 inch tubes to get stack in there. Any recommendations regarding this issue? I've heard of people doing it both ways.WickedWagens wrote:Wow! that is quite a change. Are you planning on doing any sort of transition(like a velocity stack) where the individual runners take off from the plenums?
Thanks for the compliments guys.
