No but you can check for the diffrence in the readings vs your sensor and guage.
Mario don't you have AT and CHT with the Megasquirt? SDS uses both.
Cylinder Head Temp
- Stripped66
Re: Cylinder Head Temp
Don't confuse a cylinder temp sender (the screw-in sender for warm-up enrichments) with a true thermocouple; the SDS does not have thermocouple inputs.shag55 wrote:SDS uses both.
IIRC, there is an add-on thermocouple board for MegaSquirt which makes this possible.
- Vee Dub Nut
Yup
This is one:
http://www.symtechlabs.com/catalog/mega ... -p-49.html
And there was a guy that made a four channel on the MS forums. Don't know much about it.
http://www.msextra.com/forums/viewtopic ... le#p248708
This is one:
