type 4 turbo 2.0L
Wally
Re: type 4 turbo 2.0L
Post by Wally »
sweetlokin66 wrote:
What do you guys think about the turbo?
GT2560 its too small. Really. Especially the turbine wheels are too small.
Only the Gt3076R has a 60mm turbine wheel, even the 3071R has the smaller 56mm.
Any turbo will run though and perform well, thats usually not a problem.
Just my 2 cents.
tango
Post by tango »
Hi,
Nice welds and fab.
I am running a GT28R on a 2.0 with 7.5:1 static and webcam 119 in my 914. Currently I am using a 10psi wastegate but I just got the Megasquirt boost controller hooked up to go higher, I just need to finish that off.
It comes on early enough for me and loses rear traction quite easily so I just squeezed some 225/50/16 on the rear.
I am still tweaking, the weather looks OK at the moment so maybe go for a run and post up the log later so you can see how it boosts.
I am using 1.5in header
Wally
Post by Wally »
If you want early spool ^^ that is a very nice combination! Did you ever dyno it?
sweetlokin66
Post by sweetlokin66 »
It probably would have helped to put up what I was after goal wise for the motor first. Im trying to keep it at 2.0 liter maybe 2.2. Im going to have stock 2 liter amc heads with upgraded springs and stainless valves, but the sizes are staying the same. Im attempting to make around 200-270. MAYBE 300, but I dont know if the stock valve sizes would support that. The GT2560 aka GT28R turbo claims to support up to that and then some. Early spool is the biggest thing for me since ill be doing a lot of around town driving. Ill be able to make 5 psi around 2500 rpm with the 2560R. That im hoping not to add another 600 my budget going with a GT2860R - 707160 - 5 :lol:. I plan on making a 4-2-1 header that goes from 1.5 ID to 1.625 ID to 1.75 ID that feeds the turbo.
70dragbug
Post by 70dragbug »
Great Project and fantastic welding!
I agree with Wally - don´t be afraid to use a larger turbo.The 2560 is too small.That would work well on a 1.7 or 1.8.
A GT28R or equivelant would suit the motor better and will reach your HP goal easily,keeping the intake temperature lower than with a smaller turbo that is less efficient in that range.For around town driving,you don´t really want to be on boost.If you want the motor to be more efficient and responsive in the low rpm range increase your static compression ratio.8:1 or 8.5:1 would be good.A higher compressio ratio will improve your gas mileage aswell and make the engine more efficient,and it would be easier mapping when the engine is at idle or partial load.
sweetlokin66
Thanks my pops is helping me out on the welding bit, ive just been tacking everything up. Im looking into a GT28R. I sent an email to shag about a turbo, looks like hes helped a few people out here. Id rather try and do it right once.
CobraJet
Post by CobraJet »
I agreeing with what has already been said but I want to say again, NICE fabrication and welding!!! I hope to do something along those lines on the 2.0 I'll be building this year. I like the way you positioned your intercooler, nice and close as possible to the valves.
I have a question in regards to building the intake logs as you have them. Is there an advantage in doing it this way instead of building an intake that looks like a tuned header? The reason I ask is I was thinking about building matched intake runners for mine. What do you think?
In regards to the Ebay turbo you posted the link for, why choose one that already has a waste gate if you plan on a separate one?
Keep up the great work and lots of pictures please. I'm subscribed!
nein14
Post by nein14 »
what do you think of using a KKK 26 turbo from a Audi 5000 S with a stock 2.0 type 4 with CIS bosch injection with injectors from a 6.9 litre Mercedes 450 sl ?
sweetlokin66
CobraJet wrote:I agreeing with what has already been said but I want to say again, NICE fabrication and welding!!! I hope to do something along those lines on the 2.0 I'll be building this year. I like the way you positioned your intercooler, nice and close as possible to the valves.
My intakes reduce in taper from the opening of the base to the head of the valve to increase intake velocity. I wanted to use stock base because its direct port injection. I also built the radius into the baseplate because I didnt want intake velocity stacks to intterupt the flow into the plentums.
The alternative wastegate looking part is actually a BOV (blow off Valve). It goes on the intake runner between the turbo and the throttle body.
I have been talking to shagg and just purchased a turbo tonight from him. I also got some stub flanges from tiger at A-1 on the way so I can start on the exhaust.
Also just got some nice AMC head castings :twisted:
It's comming together.
itawolf
Post by itawolf »
What AMC castings did you get???
Heck im sure we'll see pic's--but hey im hungry!! :twisted:
RET Marine 0317 --with VW on the lobe!!
Lots of iron in the fire
sweetlokin66
Some low mileage 2.0 liters. Im putting in stainless valves and cutting the intake seats to 45*. It already has dual springs installed however I might get some different springs as well.
sweetlokin66
Need to be cleaned up!
got some new stuff from the junkyard.
Dont have any picts of the fuel pump but I picked up one :lol:
sweetlokin66
And it begins :twisted:
Wally
Post by Wally »
Nice tubes collection you ordered, but how did you know exactly what you needed?
I always seem to need just a different bend or length once I start making the thing...and that several times... :|
Turbo Farviknugn
Post by Turbo Farviknugn »
WHAT is this going in ??? Just so I know what NOT to mess with IF I see it on the streets ! :lol:
REALLY NICE BUILD !!!!!
