Powder Coating. Beats Paint by a mile. And you can do it at home fairly cheap. (well,.... you CAN do it cheap, I have over $10k in coating equipment now.... after 3 years of a "hobby" and looking to upgrade soon.) You only need to cool things down when done curing. No dry time. Handle it as soon as it's cool. Install it and go.Ol'fogasaurus wrote:It is currently in the low 20 and snowing in the PNW. Up here if it isn't raining the fog is out while in the sunny SW I am sure it is chain or wire rope season. While painting small stuff, I used to hang things off any where in the garage I could find; e.g., door handles, the rails for the garage door, my wife when I could get her to stop long enough, etc. Yesterday I was able to get some painting done after the snow, rain, sleet, hail had stopped and while the sun was out ( temp in the low 20's) then bring them back in and hang them on my stand to dry. It is really too cold in the garage (mid 40's) for them to dry correctly so there is a skim coating on them and the under the surface paint is still only partly cooked.
Actually, the stand has turned out better than I thought; it is still light enough to move easily, strong enough for a lot of things hanging, the base is heavy enough to hang some pretty heavy stuff on like a couple of trailing arms and backing plates. The angle pieces I added to hang to worked out better than I thought and without a lot of holes, this allows me to slide the hangers (bent welding rod) around to adjust for air drying room. I still have some holes for the really heavy stuff that I want to keep in a set position so I am very happy with it. A picture to follow.
Home Built Tools. Lets See 'Em!
- SCOTTRODS
Re: Home Built Tools. Lets See 'Em!
- theastronaut
I built this tubing roller a few years ago. The rollers can be adjusted up or down to fit thicker/thinner tubing. Has a bottle jack on one of the outside rollers.
Here's a piece I bent with it, 16 guage .5 x 1.5" rectangular steel tubing, needed to make a roof skin brace for a home-made targa top '78 Camaro. Notice that the tubing is curved in both directions.
I also welded up this stand for our shrinker/stretcher:
theastronaut, a pair of very cool tools, thank you.
GA_Boy
I posted this a couple of years ago. It's a homemade jack scale.
http://www.shoptalkforums.com/viewtopic ... 9&t=125881
NOTE TO MODERATOR: Delete if I broke the rule of posting in two places.
Marvin
Marvin
pickstock
can we make this a sticky???
Klaus our adventures in building a rally beetle.
https://www.youtube.com/channel/UCWH4s3 ... 4KnPES3_A/
- david58
Here is a pic I found on the internet.
hugging corners
i have made up 35 steps, by myself minutes after pic taken:)
its an pressure washer cart, but it already was used for 110 welder.
total chopjob. metal triangles with pipe inside was found after some TV event- dumpsterdivin style
PS: jan 2012
I have just worked out a power station for:
1. electrolises.
2. BIG jumper
3. ..and maybe it work as a "Surge" protector for my 110v welder
Last edited by hugging corners on Thu Jan 05, 2012 7:59 am, edited 6 times in total.
D.G.F
this is a puller that i made to pull stuck arms off and bushings..
- EAW
I like this a lot, It's so annoying having to drag the jack across bumpy surfaces, could even make a low profile one for lowered cars...david58 wrote:Here is a pic I found on the internet.
“It’s not the critic that counts, not the man who points out how the strong man stumbles or where the doer of deeds could’ve done them better – the credit belongs to the man who is actually in the arena.”- Theodore Roosevelt
- birddog1148
press brake for HF 20 ton press
- SCOTTRODS
Are you using a hydraulic/pneumatic adaptation to power that thing? or using the slow "pump it up" method? Nice adaptation either way.birddog1148 wrote:press brake for HF 20 ton press
- birddog1148
PUMP IT UP!
At least for now.
At least for now.
- turboblue
Pretty cool.
I wonder if it has a stop/stiff leg of some sort at the front axle.
If not the jack might topple over if a tire blew out.
I assume they are pneumatic.........look so anyway........
cedric
My homemade tools for measurement of the stretch of the bolds of arp,empi ect,.....
- vdubsinjensen
