Synthetic oil is good for air-cool engine
sagaboy
Re: Synthetic oil is good for air-cool engine
Post by sagaboy »
After switching over and using synthetic oil for a couple of weeks--it no longer takes 12 KM for the oil to reach working temperature 180F. Now it only take 3 to 4 KM for it to be 180F and upon checking the oil, it is much dirtier and normal, it show that better quality detergent in the synthetic are really cleaning up the engine and with a cleaner engine--the heat are being absorbed faster by the synthetic oil.
Ragtop67
Post by Ragtop67 »
aussiebug wrote: Sat May 21, 2011 1:32 am I am pleased to see Piledriver and Rockerarm have introduced more than the simple Dino/synthetic question here.
It's a lot bigger question than "are synthetic oils better?"
ALL oils have improved out of sight in the last 40 or more years.
The problem is that we are trying to compare MODERN oils with the needs of our OLD engines. Modern oils are developed for modern cars, not 40 year old ones. Engines design has improved a lot in that time, and oil technology is trying to keep up.
So lets have a look at it.
Lubrication
VW used to recommend single weight oils which had to be changed with different ambient temperature ranges. Then in about 1975, when multigrades became reliable, they started recommended mulitgrades. They always stated in the Owner's Manuals that any good brand HD (that's High Detergent, not Heavy Duty as some would think) oil was OK, and this made sense as the car was sold all over the world so good oil anywhere would do the job - the engine was not too fussy about the brand so long as it was a good oil. Almost all 4-stroke engine oils back then had large amounts of ZDDP added - up to about 1400PPM.
Oil is supposed to prevent metal to metal contact in an engine - maintain a film of oil between all moving parts. But our flat tappet engines need more than just oil - they need an anti scuff agent to stop metal to metal contact in those high pressure areas like the flat tappets. To do this, oil engineers have long used an additive called ZDDP (a Zinc/Phosphorus compound). As luck would have it - this compound is also an excellent antioxidant, so it also helps cope with the corrosive combustion by-products that get into the oil.
ZDDP is sacrificial.
1. It works as an anti-scuff agent by decomposing with the heat of microscopic metal/metal contact and coats the contact area with Zinc, which eventually wears off and so the process repeates. This zinc coating reduces the wear on cams and tappets, but does not eleminate it completely.
2. It chemically combines with combustion by-products to produce less damaging chemicals in the oil.
So you need enough of the stuff in the oil to last until you change the oil again.
Modern engines need less or none because they usually have roller tappets, and the engine computers used these days control the combustion process much better than a carburettor or mechanical FI ever could, reducing the amount of combustion by-products significantly.
Cooling
Overcooling and undercooling are equally damaging. Ovecooling increases the viscosity of the oil and the engine is always designed to work with a set range of viscosities - obviously an over-thick oil will not flow as well as one which is "just right". Under cooling will increase the oil temp and reduce the viscosity, risking more metal/metal contact.
Another factor not often known about is that for ZDDP to work, the oil MUST be hot - I had a long discussion with a 30 year oil engineer at Castrol Australia who stated that ZDDP will not get to a high enough temperature at the metal/metal contact point to decompose and do it's job, unless the general oil temp is above 80c (176f).
Claims like "I use synthetic oil because the oil temp goes way down" might be completely anti-productive.
Summary
Oil manufacturers are reducing the maount of ZDDP in oils as it posions catalytic converters. Manufacturers are designing engines with roller tappets so they do not need so much (or any) ZDDP in the oil.
Many modern oils do not have much if any ZDDP, which our old engines still need.
Synthetic v Dino oils.
It doesn't really matter that much in terms of lubrication in general - both will do the job. They will both also carry engine heat to the oil cooler much the same. And both have changed there formulations a lot in recent years, so either could be right or wrong for our old engines. But I do not know of any synthetic oils which have significant levels of ZDDP (let me know if there are some).
The Castrol Engineer I spoke to said that despite the out-of-sight improvment in oil technology in recent years, our old engines will last longer if they have some ZDDP in the additive package. In Australia Castrol Edge Sport oils have a higher level of ZDDP than most - above 800PPM. But oil formulations around the world do differ, so we as owners, must determine if the MODERN oils available locally to us meet the requirement of our OLD engines. In many cases, certain oils are only available in certain countries - Royal Purple and Brad Penn in the USA, Duckhams in the UK, Penrite in Australia, and so on. And even the "common" oils like Castrol, Shell, and BP use different formulations in different countries.
So we have to consider the WHOLE deal - lubrication, viscosity, additive package - it's not enough to say "it runs cooler with this particular oil", or "I change my oil every 1000 miles to it doesn't matter what I use".
It's a little harder for us these days, because oil technoilogy has moved on from our old engine designs...we have to get a little more choosy ourselves, and to do that, we need enough knowledge to make the right choices.
I guess the average aircooled VW owner has to be smarter than the average bear :-)
Excellent write up!
I'd just like to add that there are indeed synthetic oils with high zddp content! Any diesel/turbo diesel have enough for our bugs. I use Mobil 1 turbo diesel which has 1200ppm zinc ;)
duplicate
...And there are modern ep additives tbat work far better than zddp.
My nasty old aircooled engines seem to go 400k miles in this horrible modern oil crap, the main bearing still looking new.
Must be an outlier.
Bruce.m
Post by Bruce.m »
I used to use Castrol habitually but have moved over to Mobile 1 5w30 in all my cars.
Aircooled engine seems to like it and I get plenty of oil pressure despite being a modern thin oil. No leaks either because I was careful on assembly (did have one leak due to a poorly sealed oil bore plug but fixed that)
...Come to think of it, I stopped using Castrol GTX after I wiped 2 cam/lifter setups in a row with it.
(this was after the unannounced reformulation to 800ppm ZDDP with nothing to replace it)
Went to Rotella T6. 5w-40, Mobil1 TDT or QS Ultimate Durability.
Won't use Castrol products anymore, not worth it.
Modern synthetics are generally far better/more stable at high temperatures (even G3 base), so fare better in aircooled engines.
...Especially running 12K mile oil change intervals on a T4. Mobil1 or Purolator One filter.
Bruce.m
Post by Bruce.m »
You make a good point about filters. Doubt I’d run an engine without one anymore. Used a copy of the Mexican 1600i pump/filter on my current engine and that encouraged my brother to ask for the same on the engine I’m building him. Not sure I’d run synthetic without a filter.
HandOverFist
Post by HandOverFist »
Piledriver wrote: Tue Jan 30, 2024 10:29 am ...Come to think of it, I stopped using Castrol GTX after I wiped 2 cam/lifter setups in a row with it.
More likely the reason you had failures with Castrol oil has nothing to do with ZDDP content. When Castrol was last sold the purchaser right off the bat reduced the additive packages across the entire board making their oils utter garbage. The consumer had no clue about what had been done. Fun fact - The current 800ppm ZDDP content in modern oils is exactly the same as it was for all oils in the 1960's...the heyday of high performance flat tappet engines.
More ZDDP content offers zero extra protection...it merely extends the depletion time. Another fun fact - If you research used oil analysis samples you will find the depletion rates of ZDDP to be miniscule. If it is unbiased and truth about oil you seek I would suggest start your journey here... https://540ratblog.wordpress.com/2013/0 ... t-ranking/
That's where I read about the QS Ultimate Durability oil...
Just wish it was diesel rated.
Bruce2
Post by Bruce2 »
sagaboy wrote: Thu May 05, 2011 8:41 pm It took 25KM of mix highway and street driving on 10/30wt dino oil for the oil to barely reach 170F
After switching to BP Synthetic 10/40wt oil it only took 12KM for the oil to reach 180F and with higher/faster idling engine speed plus more power/torque.
From my observation, it is obvious that Synthetic oil have the unique ability to absorb heat from moving parts of the engine or that heat from the engine moving parts are easily transferred the Synthetic oil which translate to a cooler engine with less wear and tear.
Old post but I'll reply anyway...
Your conclusion is incorrect. The reason the new synthetic oil got up to temp faster is because of its viscosity, a -40 instead of a -30. By using the thicker oil, your oil pressure went up. This caused the rear plunger to bypass the oil cooler while the engine was warming up, making the oil get hotter quicker.
If you want to test the theory that synthetics lubricate better, you can't change multiple variables at the same time. Test a 10W-30 dino oil against a 10W-30 synthetic. Preferably from the same manufacturer.
1) What Bruce said.
2)REALLY fast warmup is actually desirable. You should try it with a real oil thermostat, and ideally a factory style air flap/bellows setup, and on a T1 a true full flow filter off the main loop, not the oil cooler bypass loop.(AKA faux flow filtration as FJCamper likes to say)
With that and a high efficiency air filter media (not oiled gauze that barely stops rocks) you may find your aircooled engine lasts 2-3x longer between rebuilds.
OEMs work that hard for emissions reasons, but the engine also lasts a lot longer as a huge side benefit.
