Max's 1776 EFI Turbo Build
maxyray
Re: Max's 1776 EFI Turbo Build
Post by maxyray »
yvre wrote:Indeed... You put 3 as pressure ratio instead of 2.
Max
maxyray
Post by maxyray »
As I'm still undecided whether or not to use one of my two Garrett GT1752 turbos or to buy a GT25 or T3. I thought I would put up some pictures of the new fuel lines fitted.
Here is a pic of the 5/16" Fuel hard lines too and from the tank. I used Stainless Steel P clips to attach the lines. :D
Here is where it comes out through the bulkhead. The Fuel pump and filter will be fitted to one side of the chassis tunnel.
Ps if anyone's got any advice on turbo choices for my 1776 let me know.
Max
yvre
Post by yvre »
Just try the one you have.
Coyote
Post by Coyote »
Do you plan to drag race it?
if so, the fuel lines must be located outside the driver compartment.
As for the turbo, try the one that you have.
2276cc daily draw though
ET: 11.67
MPH: 119.64
maxyray
Post by maxyray »
Coyote wrote:Do you plan to drag race it?
No just driving it on the street.
Coyote wrote: As for the turbo, try the one that you have.
yvre wrote:Just try the one you have.
Yeah maybe I should just try it out. Can always swap it over later to a GT25 or T3. :D
Max
Coyote
Post by Coyote »
That's fine ! Welcome in the boost addicts club ! :lol:
ET: 11.67
MPH: 119.64
maxyray
Post by maxyray »
:lol: Thanks. Can't wait. :twisted:
Max
dejan
Post by dejan »
I started working with map , I need to finish
should look like this
This is perfectly :D :D
maxyray
Post by maxyray »
dejan wrote:I started working with map , I need to finish
Thanks for that Dejan. So according to the map I'm ok running my gt17 on a 1776 then?
8)
Max
maxyray
Post by maxyray »
What are you turbo guys running when it comes to exhaust gaskets? I've got a new CB Performance buggy turbo header.
It's a T04 flange so will have to fab up an gt17 adapter.
http://www.cbperformance.com/catalog.asp?ProductID=308
Max
Clonebug
Post by Clonebug »
I am running a set of slip in copper exhaust gaskets on my el cheapo sedan header at the heads. They have never leaked up to 13 plus lbs. of boost.
Mine are 1 1/2 inch style. I don't know what size these are though. I bought mine six or seven years ago and have used them since I started driving my buggy turboed and non turboed. You will have to ask to get the right size if you are going for a 1 5/8 inch header.
http://www.vwparts.net/BP2512-20.html
I also use the large copper gasket at the flange of the header to my turbo up pipe. It did leak just a little bit but never seemed to cause any problems.
http://www.vwparts.net/CB3641.html
I plan to seal that up when I reassemble my system.
I have heard of some using high temp gasket sealer for a gasket also.
Clonebug
Coyote
Post by Coyote »
GT 17 flange gasket are available, like this one for example :
http://www.ebay.com/itm/Garrett-Turbo-S ... 5890306bb4
ET: 11.67
MPH: 119.64
maxyray
Post by maxyray »
Clonebug wrote:I am running a set of slip in copper exhaust gaskets on my el cheapo sedan header at the heads. They have never leaked up to 13 plus lbs. of boost.
Clonebug
Thanks Clonebug for the info. I'll have to see if I can get hold of some in the UK.
:D
Coyote wrote:GT 17 flange gasket are available, like this one for example :
I was talking about fabricating something like this.
http://item.mobileweb.ebay.com/viewitem ... 0868024071
I've already got the gaskets thanks. :D
Max
maxyray
Post by maxyray »
Would like some help on choosing a cam...
1. Engle W100 .420 lift x 276 duration.
2. Webcam 119 .422 lift x 276 duration.
3. Webcam 218 .460 lift x 280 duration.
CR is 7.5 and I'm using stock rockers.
Anyone?
:D
Max
dejan
Post by dejan »
I think that would satisfy any but the most often 1776cc built with , W120 or VZ-15,VZ-25 in more recent times.
