I know about modern relays and extra demands on the electrical system...Max Welton wrote:That is pretty nifty. I didn't know about Blue Sea systems.
But one of my objectives is to do away with the old-style relays and flashers (like the stock 9-pin relay). The integrated assembly approach does away with those as well as the wires related to them.
I will also be adding equipment not found on the original car, such as two relays to control a Megasquirt ECU and FI pump, a collection of gauges and sound system to be located in the center console I haven't designed yet, perhaps some small cabin lights. Stuff like that...
Max
Our `69 has a Rabbit fuel pump relay, a 3-pin flasher relay, two relays to control the retained accessory power, a hi/low relay, a high beam relay, a low beam relay, an accessory relay, a rear window defrost relay, a starter solenoid relay, a relay for the Type IV heat booster fan under the backseat, and a 75A relay to control the Blue Sea fuse panel. It also has a cylinder head temp, tach, and oil pressure gauge. I've added a Secret Audio stereo setup w/the head-unit remotely mounted behind the backseat, with the control LCD screen/buttons recessed into the glovebox door. I've also added Rossi headlights with an extra park lamp as well as late model Jetta sidemarkers that operate as both park and turn signals. It's also got a Cole Hersee wiper switch, with hi/low/and 2-20 second intermittent; as well as a push-to-wash feature that operates a Mexi Beetle reservoir & pump - it wipes the screen automatically a couple times and parks the blades. I'm soon to be adding a late two-speed dash fan as well.
There's a Dakota Digital unit that gives you retained power when you turn off the car, and breaks it when you open the door(s) and has a headlight sensor that controls the headlights automatically...I also installed a Gentex rearview mirror w/compass, thermometer, LED map lights (w/push-button override on the dash via a re-wired stock brake warning indicator), and auto-dimming. Today I installed a second factory domelight and modified two stock switches to operate them in a certain way - both may be controlled from the driver's side.
I also installed a second OEM fuse panel behind the passenger seat in our `73 Bus, next to an additional battery, a 200W amp, and another 75A relay.
