Well we finished the welding on the pan putting the jack point back on and cleaned it up for paint started with a good coat of POR15 here it is wet as we headed out of the garage for some fresh air
Also got the fan shroud sand blasted and painted up
Alex
|_________oo_oo
/ /__/____[_____\
I I======[]IIIIIII[]
()_)-----()_)----)_)
I picked up a super nose just for the kick panel / fire wall it is in pretty good shape and a lot better than the body for the car
It came with a late style idler arm with a good bronze bushing so that got cleaned up and painted ready for rebuild
And an order of cables one set of heater control cables and 2 each of clutch and accelerator so there should always be a spare in the car and some shift components to rebuild that system
Alex
|_________oo_oo
/ /__/____[_____\
While we had the nose that is much lighter than the entire body I felt it prudent to do a test fit and it showed an issue, the nose rocks on the 2 ends of the Napoleons hat and there is a large gap between the body and the napoleons hat.
Here is the pad on the body where it is sitting high
It seems to be sitting high because these raised sections on the napoleons hat
Should I cut those pads off and try to make them level with the area around them? Or should I try to bend the napoleons hat ends down the do seem to be a little higher and maybe not as flat as they should be almost like a W.
Alex
|_________oo_oo
/ /__/____[_____\
