Slick, like a wittle bitty Whipple supercharger.MarioVelotta wrote:You can go with the newwer screw model, more output, and suppose to be very quiet if not silent.
In-line Screw Pump 330LPH, High-Pressure (Pierburg P/N 7.00228.51)
I found them cheaper but there is good info here
http://www.racetronix.biz/itemdesc.asp? ... 30&eq=&Tp=
Fuel pump died, what pump now?
Re: Fuel pump died, what pump now?
- MarioVelotta
I so want one, or two when I can turn on the boost again.Piledriver wrote:Slick, like a wittle bitty Whipple supercharger.MarioVelotta wrote:You can go with the newwer screw model, more output, and suppose to be very quiet if not silent.
[email protected]
[email protected]
One forum that mentioned them had a post that theorized there was only one way those got smuggled out of Bugatti...
(I would have guessed in a thermos, but there are other possibilities
The last Pierburg pump I bought didn't even last a year. Not going that route again. It was $150 bucks our shop cost. It was a cross reference model to a Porsche 928 pump that I ran on my baja. I only run Bosch now.
Steve
My Baja Build
My Baja Build
- MarioVelotta
One failure and you give up on a brand all together?Steve Arndt wrote:The last Pierburg pump I bought didn't even last a year. Not going that route again. It was $150 bucks our shop cost. It was a cross reference model to a Porsche 928 pump that I ran on my baja. I only run Bosch now.
[email protected]
[email protected]
That is 100% for me. LOL
My dad's shop installs probably 10 pumps a month. He warned me when I cheeped out buying the off brand copy pump.
One tip off was the motor on the Pierburg 928 replacement pump I bought was less than half the size of the same part number Bosch. They just put a big rubber casing on it to make the diameters the same. It was nice and quiet when it worked.
Steve
My Baja Build
My Baja Build
- MarioVelotta
After doing my research the other night, the ones used in the supercars are brushless and require a controller. The reference number is E5LM, info here - http://www.mepax.com/?page=produit&prod_id=55Piledriver wrote:
(I would have guessed in a thermos, but there are other possibilities)
This is the little brother... But still capable of lots of fuel at high pressure. If you would like the full specs they are here - http://art.rexbo.net/pierburg/pdf/pg-pi ... en-web.pdf
[email protected]
[email protected]
Pierburg isn't really the same company anymore.
(subsidiary of TI Automotive...)
Bosch isn't really the same quality it once was either...
I'd consider one of those if I didn't have room for a feeder and sump, as they at least have some vertical draw capability, so they can actually suck. The brushless setup sounds trick, but are probably stupid expensive.
A 044 has better specs than the top of the line version of the E3L, and lower max current draw... Roller cell pumps do really prefer a feeder though.
- woodsbuggy1
I am running a used factory Subie pump in my fuel tank and it is still working great with E85. I have a spare but it is hard to beat the quality of OE parts.
Kenric
Kenric
