Page 2 of 3
Re: Common car fuel pumps?
Posted: Tue Jan 06, 2015 2:55 pm
by Bruce.m
Try Tracy Tools (Google it) for NPT taps
Posted: Tue Jan 06, 2015 3:10 pm
by andy198712
Bruce.m wrote:Try Tracy Tools (Google it) for NPT taps
£6 not bad!! Will look up postage tomorrow at home
Thanks!
Posted: Tue Jan 06, 2015 5:10 pm
by Clonebug
Just make sure you can get NPT brass tee's.
Posted: Wed Jan 07, 2015 12:37 pm
by andy198712
Clonebug wrote:Just make sure you can get NPT brass tee's.
I'm also wondering if 1/4NPT is like 1/4BSP ect
Or i just buy a swirl tank, seen VW made one from an old golf or something? had an IN, VENT, OUT, RETURN .... can use an 8mm outlet tank piece maybe...
Posted: Thu Jan 08, 2015 7:15 pm
by Clonebug
That would be too easy
....if you could find one.
Posted: Fri Jan 09, 2015 5:55 am
by andy198712
Clonebug wrote:That would be too easy
Just thought, what if I could walk into the dealer and buy one! Doubt I'd be THAT lucky mind!!
Posted: Fri Jan 09, 2015 7:10 am
by Clonebug
andy198712 wrote:Clonebug wrote:That would be too easy
I think it was Pile that said they were available at the local "FLAPS".
You could try there too.
Didn't the VW Fox use them???
Posted: Fri Jan 09, 2015 7:29 am
by andy198712
will have to look into it, need a uk suppler also. seems as easy route to go though!!
Posted: Fri Jan 09, 2015 7:36 am
by andy198712
anyone know what VW called these things?
Posted: Sat Jan 10, 2015 3:09 pm
by squeakie
I don't know if these are any good (quality), but the price seems right:
http://www.ebay.com/itm/2L-Universal-Al ... 86&vxp=mtr
Posted: Tue Jan 13, 2015 9:28 pm
by raygreenwood
andy198712 wrote:anyone know what VW called these things?
Are you talking about the fuel pressure accumulator from a CIS injected car?
Posted: Wed Jan 14, 2015 1:00 am
I think I mentioned at some point using the plastic sump recirc tank off later Golfs/cabbies/Fox etc.
I think the nomenclature was "filter" or something equally idiotic for a ~transparent hollow plastic enclosure with a bunch of tubes sticking out..
Posted: Wed Jan 21, 2015 10:01 am
by andy198712
They turned out to be pretty pricey here in the UK new, around £80 which is about $150??
What about that vent in the corner of the tank, as you look in under the bonet from the front of the car its bottom right, couldn't i just put my return into that??
Posted: Sat Aug 15, 2015 2:05 am
by andy198712
anyone tried that? or the port in the filler neck? looking to get this rolling next month
Posted: Sat Aug 15, 2015 4:59 pm
by Jadewombat
I use a Bosch pump off a mid-70s VW bus and the fuel filter. The inlet side of the filter is 6mm I think? and 8mm outlet?? It's smaller on the inlet side than the outlet though.
